How Narrowly Can Stone Be Cut For A Counter? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 10-27-2012, 01:12 AM   #1
How narrowly can stone be cut for a counter?
I'm planning to replace the plastic laminate countertop on a center island with silestone or some other stone(-like) surface. At the same time, I'd like to install a 30" wide gas cooktop at one end (we have an electric cooktop elsewhere, but the wife would like the gas option as well). That would leave a 3"+/- edge on 3 sides of the cooktop --- supported only by the vertical cabinet walls below on the inside edge. In effect that 3" edge is cantilevered out from the cabinet.
Is this an impossible situation? Is there a stone that would be better than the others? I read that r-bar can be imbedded in silestone; might that work?
Last resort, I guess I can try to persuade my wife to go with a 24" wide cooktop.
onthebrinck is offline   Reply With Quote
Old 10-27-2012, 08:10 PM   #2
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
I'm having trouble picturing this. A scale drawing may help.
I will mention you will probably regret not having any counter space directly next to your cooktop. Where will you put the mixing spoons, measuring cup, ingredient bowls, etc. etc?
Old 10-27-2012, 08:21 PM   #3
GBrackins's Avatar
Rewards Points: 2,108
and if the cooktop is installed in an island will you be using a down draft exhaust vent?
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 10-28-2012, 01:35 AM   #4
Yes, I will.
After further consideration I have decided to rotate the cooktop 90 degrees, which will alleviate the edge problem and provide the work space.
Heavy natural stone wall tile: mastic or thinset? Is drywall adequate? Minich Remodeling 8 02-01-2012 08:27 AM
attaching countertop analogmusicman General DIY Discussions 22 08-10-2008 11:53 AM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
Stone counter fabrication slakker Building & Construction 1 06-03-2007 12:50 PM
