Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling > Kitchen & Bath Remodeling
Old 03-13-2011, 04:56 PM   #1
How to fix a Shower Pan that's not level?
The shower is a fiberglass 4 piece unit. The pan was not properly leveled when it was installed. The pan is connected to the 3 walls. The glass door doesn't line up properly to the base of the pan. Also, the water runs to the low corner (front left corner when looking at the opening) instead of to the drain.
Is there a way to level the pan without ripping everything out?
derrett001 is offline   Reply With Quote
Old 03-13-2011, 05:15 PM   #2
Everything is sitting on the base. You can't level it without taking off the wall material.
Ron
Old 03-17-2011, 04:32 PM   #3
Ron - Thanks for your reply. Shoot! The one thing I don't want to do is rip out the existing walls and then the shower pan. Can you think of anything else to try?
Old 03-17-2011, 04:49 PM   #4
Tileguy
Bud Cline's Avatar
Ron ?
Old 03-17-2011, 05:48 PM   #5
Magic wand or pull it down. Choices are limited.
Ron
Delta Jetted Shower - install problems . . . Eusibius2 Plumbing 7 11-13-2009 12:21 AM
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 10:10 AM
Hiding shower pipes Jackamus Kitchen & Bath Remodeling 2 10-29-2009 05:30 AM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 01:39 PM
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 11:42 AM
