How To Fix Ceramic Towel Rack That Got Knocked Out Of The Wall? There Are 2 Square Holes Now On Each Side To The Wall? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 06-24-2010, 10:51 AM   #1
How to fix Ceramic towel rack that got knocked out of the wall? There are 2 square holes now on each side to the wall?
I have 2 square holes in the wall and I also have the bar, and the 2 ceramic ends to the towel rack and I was wondering , How I secure those back in the wall?
nicki3174 is offline   Reply With Quote
The Following User Says Thank You to nicki3174 For This Useful Post:
charski (03-31-2012)
Old 06-24-2010, 10:53 AM   #2
booey9 is offline   Reply With Quote
Old 06-24-2010, 10:58 AM   #3
Why 2 logins to ask the same question ?
The 2nd login has been disabled
Old 06-24-2010, 12:42 PM   #4
Handyman
Rewards Points: 512
His and hers?
You could use a bit of tile mastic but PL Premium might be best.
canadaclub is offline   Reply With Quote
Old 06-24-2010, 05:53 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Tile Mastic IS NOT a proper adhesive for towel bars.
How deep are the holes?
What's the wall made of?
What type of adhesive was used previously, does it look like cement?
XXX
Old 06-24-2010, 06:29 PM   #6
Handyman
Rewards Points: 512
No disrespect Bud, but you are asking questions which any tiler or bathroom renovator has seen way too often. The OP is asking for a solution...not a rebuild. To ask how deep and material says nothing.
I already knew what she meant.
Tile mastic works well as an adhesive if given time to dry. My pref was PL which would be stronger, regardless of the surface from where the rack came off.
I have come across a ton of the white/clear towel racks..as well as soap dishes which have fallen off.
My advice is earnest..if you have an opposing view, state it (sans CAPS)
and I will read read it but please don't usurp my knowledge. I wouldn't do that to you.
The Following User Says Thank You to canadaclub For This Useful Post:
oh'mike (06-24-2010)
Old 06-24-2010, 07:20 PM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Likely because they were all installed with mastic as the installers breezed through the installation and installed the towel bars the same as the tile. I rest my case.
This was asked in an effort to determine if this could possibly be a mud job installation. If it is steps have to be taken to repair the holes in the wall, remove the old mortar, and reattach the holders.
This was asked in an effort to determine if the walls are clad with drywall.
This was asked in an effort to determine if the adhesive was brown, yellow, or grey. A response to this question could determine if mastic was in fact the culprit to begin with.
The OP didn't mention how they got "knocked out of the wall". Towel bars properly installed don't just get "knocked out of a wall" that easily. Towel bars installed with mastic do.
True, but nicki isn't claiming to be a bathroom renovator.
Different installers use different methods and there should be room for both of us here. Any "qualified" installer knows that tile mastic IS NOT SUITABLE FOR FIXTURE INSTALLATIONS. In fact, most of the product labels state this plainly in the instructions "Limitations".
My advice is earnest..if you have an opposing view, state it (sans CAPS) and I will read read it but please don't usurp my knowledge.
OK, there you have it. The OP can take it for what it's worth.
XXX
Old 06-24-2010, 10:23 PM   #8
DIY staff
Rewards Points: 7,174
Silicone caulk is a fine adhesive for ceramic towel bars---you will want to use some strong tape to hold the items for 24 hours.---Mike---
Old 11-21-2011, 09:08 PM   #9
To CANADACLUB
[quote=canadaclub;460842]
Ceramic/Porcelin bar replacement
Your in Oakville & I am in Toronto. Where can I get a replacement for a square, 24" long bar and the two 'spring ends' for same?
It's the type of unit, although square, does not seat as a square in the ends. Regards, CM
Chas M is offline   Reply With Quote
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 4 04-04-2017 07:38 PM
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
wall shower rack in ceramic tile ProudMarineDad Building & Construction 1 07-05-2009 05:50 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
