-   Kitchen & Bath Remodeling (http://www.diychatroom.com/f80/)
-   -   How to fix Ceramic towel rack that got knocked out of the wall? There are 2 square holes now on each side to the wall? (http://www.diychatroom.com/f80/how-fix-ceramic-towel-rack-got-knocked-out-wall-there-2-square-holes-now-each-side-wall-74536/)
nicki3174 06-24-2010 10:51 AM
I have 2 square holes in the wall and I also have the bar, and the 2 ceramic ends to the towel rack and I was wondering , How I secure those back in the wall?
booey9 06-24-2010 10:53 AM
Scuba_Dave 06-24-2010 10:58 AM
Why 2 logins to ask the same question ?
The 2nd login has been disabled
canadaclub 06-24-2010 12:42 PM
His and hers?:laughing:
You could use a bit of tile mastic but PL Premium might be best.
Bud Cline 06-24-2010 05:53 PM
Tile Mastic IS NOT a proper adhesive for towel bars.
How deep are the holes?
What's the wall made of?
What type of adhesive was used previously, does it look like cement?:)
canadaclub 06-24-2010 06:29 PM
No disrespect Bud, but you are asking questions which any tiler or bathroom renovator has seen way too often. The OP is asking for a solution...not a rebuild. To ask how deep and material says nothing.
I already knew what she meant.
Tile mastic works well as an adhesive if given time to dry. My pref was PL which would be stronger, regardless of the surface from where the rack came off.
I have come across a ton of the white/clear towel racks..as well as soap dishes which have fallen off.
My advice is earnest..if you have an opposing view, state it (sans CAPS)
and I will read read it but please don't usurp my knowledge. I wouldn't do that to you.
Bud Cline 06-24-2010 07:20 PM
Likely because they were all installed with mastic as the installers breezed through the installation and installed the towel bars the same as the tile. I rest my case.
This was asked in an effort to determine if this could possibly be a mud job installation. If it is steps have to be taken to repair the holes in the wall, remove the old mortar, and reattach the holders.
This was asked in an effort to determine if the walls are clad with drywall.
This was asked in an effort to determine if the adhesive was brown, yellow, or grey. A response to this question could determine if mastic was in fact the culprit to begin with.
The OP didn't mention how they got "knocked out of the wall". Towel bars properly installed don't just get "knocked out of a wall" that easily. Towel bars installed with mastic do.:)
True, but nicki isn't claiming to be a bathroom renovator.
Different installers use different methods and there should be room for both of us here. Any "qualified" installer knows that tile mastic IS NOT SUITABLE FOR FIXTURE INSTALLATIONS. In fact, most of the product labels state this plainly in the instructions "Limitations".
My advice is earnest..if you have an opposing view, state it (sans CAPS) and I will read read it but please don't usurp my knowledge.
OK, there you have it. The OP can take it for what it's worth.:)
oh'mike 06-24-2010 10:23 PM
Silicone caulk is a fine adhesive for ceramic towel bars---you will want to use some strong tape to hold the items for 24 hours.---Mike---
Chas M 11-21-2011 09:08 PM
To CANADACLUB
[quote=canadaclub;460842]
Ceramic/Porcelin bar replacement
Your in Oakville & I am in Toronto. Where can I get a replacement for a square, 24" long bar and the two 'spring ends' for same?
It's the type of unit, although square, does not seat as a square in the ends. Regards, CM
