How To Fill Durock Board Outside Corner Joints - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 05-02-2011, 07:01 AM   #1
Rewards Points: 103
How to fill Durock board outside corner joints
Hi,
I am remodeling my bathroom. After I attach Durock Cement Boards to studs and before tiling walls I will fill straight and inside corner joints with latex-fortified mortar and alkaliresistant, fiberglass meshjoint tape. But I am not sure how to fill outside corner joints. Do I need to use the same approach or use metal corners instead of mesh tape?
Thanks.
sukhenkoi is offline   Reply With Quote
Old 05-03-2011, 10:22 AM   #2
Rewards Points: 5,336
Originally Posted by sukhenkoi View Post
Hi,
Thanks.
Same approach, mesh tape and thinset.
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
sukhenkoi (05-04-2011)
How to fill this drywall gap? kupalino Drywall & Plaster 3 02-26-2010 05:45 PM
Would you spring to fill in your backyard? Piedmont Landscaping & Lawn Care 4 05-14-2009 08:14 PM
Ridge board enough? runningforyou Roofing/Siding 9 08-13-2008 07:43 PM
Durock or Green Board oxicottin Remodeling 7 06-12-2008 06:51 PM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 10:50 PM
