How To Fasten The Towel Bar? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 10-13-2014, 11:24 AM   #1
Rewards Points: 578
How to fasten the towel bar?
My towel bar almost fell to the floor when I put on a towel. It turns out that the right anchor is loose (from the wall). See attached photos showing what the towel bar and the anchors look like.
How can I fasten the anchor to the wall?
How to fasten the towel bar?-towelbar1.jpg   How to fasten the towel bar?-towelbar2.jpg
HomeLearner is offline   Reply With Quote
Old 10-13-2014, 05:04 PM   #2
Rewards Points: 13,960
It needed to be attached to the studs, not just the drywall.
If you tried using those cheap plastic anchors they come with there useless.
Now your stuck with removing it and using large toggle bolts.
gregzoll (10-13-2014)
Old 10-13-2014, 09:08 PM   #3
Rewards Points: 578
I just bought the condo and moved in. I want to replace the cheap towel bars.
Could you explain how I can remove the towel bar with the anchors?
Old 10-13-2014, 09:13 PM   #4
Rewards Points: 582
remove the little set screw from the bottom of the brackets....the the bracket will lift off the anchor plate...
Old 10-13-2014, 09:27 PM   #5
Rewards Points: 578
I found the tiny screws. Once I took them out, the brackets and the bar were removed. Thanks for the advice!
The Following 2 Users Say Thank You to HomeLearner For This Useful Post:
ben's plumbing (10-13-2014), Startingover (10-14-2014)
best way to fasten backer board? ponch37300 Flooring 19 04-10-2017 08:46 PM
blue Scotts shop towel clog toilet pinkertonpv Plumbing 7 07-19-2014 06:51 AM
Towel Warmer Above Tub rjschwar Electrical 2 05-12-2011 05:21 PM
Hydronic Towel warmer install question bigbluedude HVAC 5 02-13-2010 07:02 AM
