How To Drill Porcelin/Ceramic Wall Tile - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 02-27-2009, 04:02 PM   #1
How to Drill Porcelin/Ceramic Wall Tile
I am installing a new shower door, and it will be necessary to drill multiple 3/16" holes in the wall tile and concrete board. Anyone have any tips or techniques to achieve this without breaking or cracking the wall tile ? What are the best type of drill bits to use? How do you cool the bits, Etc? Also, how many drill holes should i expect out of a single bit? Any help would be appreciated.
tmbrink is offline   Reply With Quote
Old 02-27-2009, 04:06 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
I'm not a pro, but whenever I drill ceramic tile, etc., I always tap a good starter point with an awl or icepick to help prevent the drill bit from skipping. You can always cool a masonry drill bit with water, sort of like a wet saw. You can tell when a bit is getting dull, then just change it.
Good luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 02-27-2009, 04:10 PM   #3
Remodeling Contractor
for porcelain and glass tiles you should use a bit made for cutting glass tiles. These finer diamonds will assure you of no cracked or chipped tiles. Ceramic tile can be drilled fine with a masonry bit.
Old 02-27-2009, 07:14 PM   #4
Man of many hats
wrangler's Avatar
Rewards Points: 354
Yeah, what Bob said. Plus a hammer drill helps. I take my vertical tracks and place them against the wall with a piece of double sided tape on the back side to hold it in place while I plumb it with my level and mark the holes with a marker (I use a wet-erase marker that I can extend the felt tip to reach through the hole). Remove the track and then start out with the 1/4" masonry bit in non-hammer mode to start, then after the bit has etched the surface, switch to hammer-mode and it will glide right through the tile, concrete backer or whatever is behind the tile. Insert your plastic anchor, tap it in flush with a hammer, replace the track and screw it in! As previously stated, glass, porcelain or real stone require different bits.
HTH,
Brett
Man of many hats
wrangler is offline   Reply With Quote
Considerations when pouring concrete against a stucco wall? clint_nichols Building & Construction 9 09-24-2009 06:28 AM
Can I install 12x12 porcelain tile on a shower wall or ceiling? dezigner80 Remodeling 6 09-15-2009 01:05 PM
installing tile. Toilet against the wall joemcjr Building & Construction 4 02-16-2009 09:49 PM
Framing a partition wall on existing carpet and ceiling tile? eagle86 Building & Construction 3 07-23-2008 04:39 PM
removing objects from tile wall lanaj7206 General DIY Discussions 5 06-30-2008 07:55 PM
