How Do You Prepare Backerboard For Fiberglass Shower Pan ? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 04-03-2013, 01:52 AM   #1
How do you prepare backerboard for fiberglass shower pan ?
My shower pan is 36in by 36in. the studs barely allow the pan to fit.
the durock is 1/2 inch like existing walls outside the shower. If I fur it out behind the rockboard it wont match up with the rest of the walls in the room. What is the best way to seal the corners of the pan where you would install the door?
BeachBoy is offline   Reply With Quote
Old 04-03-2013, 05:37 AM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 180
We just finished this same thing in our bathroom. Do you have a picture of your pan? Ours has a lip where the durock over laps the lip. I had to rip a strip the thickness of the lip to fur the durock out where it would make a smooth transition from the studs to the lip. If the tile stands proud you will have to deal with that or notch your studs where the pan will recess the thickness of the pan, but that may not work right either. Without being there it is hard to say.
Our tile with the durock stands out from the rest of the walls and most showers will. You will need a bull nose to dress that edge off.
Our tile runs out about two or three inches past the front edge of the pan and our shower door will mount onto the tile, not the wall outside the shower. I am sure there are other ways to do that but this is what we chose to do,
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
BeachBoy (04-03-2013)
Old 04-03-2013, 06:22 AM   #3
DIY staff
Rewards Points: 7,174
Bring the Durrock down to the top of the flange--no need to cover it---fill the gap with thinset as you tile---or ,better yet, fill with thinset---then waterproof the entire thing with Red Guard or Hydro ban---
Old 04-03-2013, 06:35 AM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 180
Mike how far past the top of the lip should the tile extend below? I think I may have created a lot more work than was necessary with mine.
Jim
Old 04-03-2013, 06:56 AM   #5
DIY staff
I bring the tile down to 1/8 inch above the pan----
Old 04-03-2013, 07:51 AM   #6
Ole Wood Worker
BigJim's Avatar
Rewards Points: 180
Looks like I did create more work for myself.
Jim
Old 04-03-2013, 02:54 PM   #7
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
Just read the exact samet thing in the install instructions for the base I plan on using
CoconutPete is offline   Reply With Quote
The Following User Says Thank You to CoconutPete For This Useful Post:
oh'mike (04-07-2013)
Old 04-03-2013, 07:18 PM   #8
Thanks for the help. Will mapei porcelain tile mortar enriched polymer adhere with redgard.
Do I need to put felt behind backerboard one wall is exterior with insulation with the kraft kind of paper on it r-11?
Old 04-03-2013, 08:00 PM   #9
MY pan stated leave a 1/2 inch gap to prevent water wicking kind of unclear wheather that was above the lip. that would leave a huge hole to
fill with nothing to back it to. Going to place some wood between studs to fill the gap behind pan lip so I can thinset fill it in. Thanks, Oh and I am also going to bring the backer all the way down to the top of the lip.
Old 04-03-2013, 08:05 PM   #10
Hey thanks, this is what I was thinking of doing with the redgaurd.
do you know if mapei enrich polymer porcelain tile mortar will work with redgaurd.
Old 04-04-2013, 06:49 AM   #11
DIY staff
Yep---that will work just fine-----
BigJim (04-04-2013)
Connecting shower drain to toilet drain Liv Plumbing 10 04-17-2013 11:53 PM
No pressure in my shower loki993 Plumbing 6 08-08-2012 04:09 PM
Complete bathroom redesign- need help with shower placement Liv Kitchen & Bath Remodeling 0 03-08-2012 01:00 PM
beginner's question about shower fixtures diy'er on LI Plumbing 6 02-19-2012 11:05 PM
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 10:10 AM
