How Do I Construct A Bath Side Panel? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 04-16-2005, 11:06 AM   #1
How do I construct a bath side panel?
Hi
Wanting to construct a side panel for a bath so I can tile over it, not sure where to start. Any tips.
Can I use plaster board or should I be using some stuff called "tilebacking" (they sell it in b an q).
Also wanting to make it so the 1 foot gap between the end of the bath and the wall is tiled. Any help appreciated.
jimshu2003 is offline   Reply With Quote
Old 04-29-2005, 02:31 PM   #2
you can use any wood as long as you p.v.a bond it b4 tiling the best wood to use would be marine ply,although expensive it is normally used for such jobs,but to be sure always p.v.a whatever u use b4 tiling
makaveli is offline   Reply With Quote
Old 08-07-2005, 01:10 PM   #3
bath side panel
I need to know how to cut a pvc bath panel without cracking it any advice would be great
andrew is offline   Reply With Quote
Old 08-11-2005, 06:02 AM   #4
plastic bath panel
to cut a plastic bath panel use a hacksaw blade
