How To Clean A PVC Waste Pipe From Rubber Washer Remains? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 03-04-2011, 09:33 AM   #1
Rewards Points: 105
How to clean a PVC waste pipe from rubber washer remains?
Hello,
I am remodeling my bath. I took apart my old shower cabin. First I removed all tiles and walls and then I removed the old fiberglass shower pan. A rubber washer inside of the drain completely stuck to the PVC waste pipe. I was able to cut and pull it, but now the waste pipe is covered by some rubber residue. Due to space limitations I cannot cut and replace PVC waste pipe and would like to clean the waste pipe from rubber washer remains.
Is there any easy way to clean a PVC pipe from rubber washer remains?
Thanks a lot.
sukhenkoi is offline   Reply With Quote
Old 03-04-2011, 09:53 AM   #2
DIY staff
Rewards Points: 7,174
Have you tried pvc primer/cleaner--the purple stuff?---That and a knife blade should clean that up for you.
Old 03-04-2011, 10:57 AM   #3
Rewards Points: 105
I can't use a knife because I am going to install a new shower pan and new rubber washer. I don't want to scratch the waste pipe because it may cause some water leaking problems.
But I do have the pvc primer/cleaner. I'll try. I am also thinking about trying acetone.
Thanks a lot for your advice.
Old 03-04-2011, 10:10 PM   #4
Rewards Points: 5,336
You can scrape off the high spots with a putty knife and clean off the residue by lightly sanding the pipe. As long as you don't put a vertical gouge in the pipe, you'll be fine.
Ron
Washer Drain Pipe Install somewhatsketchy Plumbing 0 10-10-2010 11:13 AM
Is yellow polyethelene or polyphenol gas pipe now the preferred gas conduit? MarkSilber Plumbing 1 09-18-2010 12:10 PM
Vent requirement for laundry washer drain pipe WaldenL Plumbing 9 01-12-2009 07:11 PM
Vent requirement for laundry washer drain pipe WaldenL Project Showcase 1 01-12-2009 04:31 PM
washer drain pipe paydelady Plumbing 3 11-13-2007 12:27 AM
