How Can I Remove Grout Sealer White Taint? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 07-20-2011, 08:01 AM   #1
Rewards Points: 105
How can I remove grout sealer white taint?
Hi,
In my bathroom I put a new floor with porcelain tiles. I grouted it and sealed the grout with two layers of water-based penetrating sealer. The sealer left white taint on the grout and tiles in few spots on the floor.
Is there any easy way to clean/remove it?
Thanks.
sukhenkoi is offline   Reply With Quote
Old 07-29-2011, 09:35 AM   #2
Rewards Points: 5,336
Try a nylon backed sponge and a liquid cleaner. Before moving to a powdered abrasive cleaner, I 'd test it on some scrap tile first.
Porcelain tile is pretty impervious, but it doesn't hurt to be cautious.
Use a stiff bristle brush on the grout.
Ron
B. Franklin 1759
Old 07-29-2011, 10:52 AM   #3
NACE Coating Inspector
mustangmike3789's Avatar
what was the water base product? was the grout cured? how long did you wait between coats? milky white areas could be moisture intrapment. if this is moisture entrapment, hot air from a hair dryer may help speed up evaporation or test a small area with alcohol or nail polish remover(acetone) to open the sealer and allow the moisture to evaporate out.
mustangmike3789 is offline   Reply With Quote
Which sealer to use that will slightly darken grout? HenryG Tiling, ceramics, marble 5 02-28-2010 08:41 PM
Cannot remove haze from tile grout Woody36 Flooring 1 10-12-2009 08:54 PM
TrafficMaster grout f.y.i. denman Flooring 16 07-01-2007 03:07 PM
Cracking floor grout - Ceramic tile DeepDish Flooring 9 03-03-2007 07:49 PM
wet space grout sealer help irlizard Flooring 2 08-15-2006 05:13 PM
