How To Build A Ceiling Soffit For Recessed Lights? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 06-03-2012, 10:52 AM   #1
annieshome64's Avatar
How to build a ceiling soffit for recessed lights?
Need to build SOFFIT in bathroom to add pot lights. Need easy to do instructions please
annieshome64 is offline   Reply With Quote
Old 06-03-2012, 11:02 AM   #2
Rewards Points: 2,210
What size of bulkhead and what style of pot lights (some attach to framing and some just clip to the drywall.)
mae-ling is offline   Reply With Quote
Old 06-03-2012, 11:16 AM   #3
bathroom bulkhead
Building from scratch
approx 60x12x8 inches or enough to get small pot lights in to give more light when in shower.
Old 06-03-2012, 12:15 PM   #4
Rewards Points: 13,444
Your only going to need one light for an area that small, I believe a standard shower kit with the gasketed trim ring is 4". Why not just install it in the ceiling that's there now?
The lower a ceiling is in a shower the better chance of mold and other problums.
Old 06-03-2012, 12:52 PM   #5
AHH, SPANS!!!
Rewards Points: 1,166
a 60" x 12" 2x8 box that is pre built and then later attached to the ceiling with screws up into the joists will probably be best to do. pre design the box with the light in mind so that the light can mount later to the drywall of the box like a pop in. maybe consider a fan light combo instead of just lights, in that case the fan would have to mount to wood in the box unlike just a pop in light. also, use the green or purple moisture control drywall instead of just regular drywall.
hand drive is offline   Reply With Quote
The Following User Says Thank You to hand drive For This Useful Post:
annieshome64 (06-03-2012)
Outside basement stairs, bulkhead stairs, etc anesthes Building & Construction 0 03-29-2011 05:33 AM
Bulkhead 295yards Drywall & Plaster 3 01-29-2011 10:27 AM
Brand new roof leaking over bulkhead pete0403 Roofing/Siding 10 01-10-2011 08:33 PM
Basement Bulkhead - replacement ideas dinohome General DIY Discussions 2 03-17-2009 06:15 AM
Adding a roof over a bulkhead? 1parkpointer Building & Construction 1 12-08-2008 09:24 AM
