How Best To Patch This Wall? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 03-06-2011, 12:07 PM   #1
Rewards Points: 282
How best to patch this wall?
As well as how best to mount this outlet?
I am in the process of installing a new dedicated 15 amp outlet for the refrigerator as recommended. It could just as easily be a 20 amp but I have just enough 14/2 conductgor left over to do it this way.
On to my main question. What is in the wall is an old cement based product that crumbles easily. Refer to my other thread On to the kitchen . You can see that my walls are not conventional. Here it looks like there are cinderblocke sitting on top of a wood beam. On top of those two courses will be the large beam that sits on top of the cinderblocks in the other thread pictures. I wasn't expecting to find that. Conventional wisdom dictates that I should open this up enough to find the wall studs and frame in for a replacement section of drywall.
The problem is there are no studs in at the level where the cinderblocks are. There is the concrete that fills in behind and in front of the steel mesh. Could I use thinset mortar to fill in this space? Or should I just keep chipping away untill I find studs to attach drywall?
I think I can just grab the steel mesh with the wings of the old work box I have.
How best to patch this wall?-p1000232.jpg   How best to patch this wall?-p1000233.jpg   How best to patch this wall?-p1000234.jpg   How best to patch this wall?-p1000236.jpg
Jim F is offline   Reply With Quote
Old 03-06-2011, 12:47 PM   #2
DIY staff
Rewards Points: 7,174
I suggest Durrabond--20 minute-(powdered bag mix)---Just trowel several coats,top with blue for easier sanding--
Jim F (03-06-2011)
Old 03-06-2011, 08:49 PM   #3
Rewards Points: 5,336
Better to mount the outlet box about 5' off the ground. It gives you a range to pull out the fridge.
Ron
Old 03-07-2011, 09:31 AM   #4
Rewards Points: 282
Ron
The refrigerator cord comes out the bottom left of the unit. How does 5 ft from floor improve my range?
Old 03-07-2011, 10:57 AM   #5
It doesn't.
Ron
Old 03-07-2011, 11:34 AM   #6
Remodeler
JCarsten's Avatar
That's the fix I use. Mix it up fairly thick for the first coat and lay it on heavy.
JCarsten is offline   Reply With Quote
Old 03-07-2011, 08:12 PM   #7
Rewards Points: 282
Do they sell Durabond 20 at Lowes or HD? I really am limited locally.
Old 03-08-2011, 07:45 AM   #8
Remodeler
JCarsten's Avatar
Yes comes in a white or brown bag. Should be in the aisle with drywall. There will be several different kinds- 5,20,45,120, etc. The number represents how much working time you have before it sets up. Make sure to grab the right one.
Old 03-08-2011, 05:02 PM   #9
Rewards Points: 282
All I found at lowes was the Sheetrock Easy Sand 90. I did finally find a hardware store that sells Durabond 90. I don't know if we've been hit harder than most by the recession but it seems like a lot of the so called supply stores in my area have a growing list of products that once sold, but no longer carry because the demand dropped off. I also found Plaster of Paris in a local paint store but I don't know if that would work the same or not.
Old 03-08-2011, 05:13 PM   #10
DIY staff
Depot has the 20 and 45--even 5 minute(That will get hard as you mix it)
The 90 will work --but 1 1/2 hours between coats? O.K. if there is an all night Indiana Jones marathon going on.-----Mike---
Old 03-09-2011, 10:07 AM   #11
If you are not going to run that wire the way it should be done, the very least you can do is protect it with conduit, rather than just mud over it.
Work is for those who can not fish.
Mop in Hand is offline   Reply With Quote
Old 03-09-2011, 05:24 PM   #12
DIY staff
Old 03-09-2011, 09:24 PM   #13
Rewards Points: 282
It may be hard to tell by the picture but there is steel mesh and going to be a half inch of Durabond 90 (90 was all I could find anywhere I'll wait) covering that conductor. They typically run through a wall cavity behind 1/2 inch of drywall. The wood beam is notch to accommodate the wire. I'm confident it will be well protected otherwise your conduit suggestion is a good one.
Wall construction for insulation support WillK Building & Construction 3 12-09-2010 01:55 PM
How to patch crack on brick wall ? anku Building & Construction 1 07-05-2009 08:30 AM
Breaking up a long/continuous wall tigereye Interior Decorating 4 03-08-2009 03:43 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
