How To Anchor A Shower Wall? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 02-27-2011, 01:23 PM   #1
lul
How to anchor a shower wall?
We would like to install a half wall with glass on top of it for our shower. It would only be anchored to one wall and not the ceiling.
lul is offline   Reply With Quote
Old 02-28-2011, 12:24 PM   #2
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
I don't have any answers, but I believe what you want to build is called a "pony wall." If you google that term you will probably find lots of info.
Edited to add: I know you didn't ask this, but if this is your first time building a shower, please be sure you fully research and understand how to waterproof it. An improperly built shower can cause a whole lotta water damage before you even realize you have a problem.
Old 03-05-2011, 08:36 PM   #3
Rewards Points: 5,336
You would need to bolt this 1/2 wall to both the floor and the wall. You should bolt this to studs in the wall and joists in the floor. If the 1/2 wall isn't aligned with both of these, you should install blocking between the studs and/or the joists.
Screw plywood to the 2 faces to increase rigidity of the wall.
This should stabilize the wall enough to build the top you want.
Ron
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 07:33 AM
Help us make a remodel decision for selling home pleas 3detailer Kitchen & Bath Remodeling 11 04-27-2010 12:36 PM
Framing Shower Wall in Bathroom Justin LaRue Kitchen & Bath Remodeling 2 06-30-2009 11:34 PM
shower head pipe snap inside of wall? snosurfa7 Plumbing 3 06-06-2009 10:15 PM
Water seeped through tiles in shower, wall ruined, need help. doogie88 Building & Construction 39 10-07-2008 05:13 PM
