How Is This Affixed? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 06-20-2014, 07:43 PM   #1
Rewards Points: 59
Question
New house purchase -- master bathroom has brass handle on the glass shower door. Any idea how it's affixed? And how I would go about changing it without destroying the door?
gnikyerffej1 is offline   Reply With Quote
Old 06-20-2014, 07:52 PM   #2
Rewards Points: 12,856
That round brass piece on the back side unscrews.
Lefty loosey.
Have you found one to replace it with?
Old 06-20-2014, 07:54 PM   #3
DIY staff
Rewards Points: 7,174
That inside piece is a nut the handle is a screw---usually--
Look at the bottom of the nut--there should be a hole that will accept an Allen wrench--stuck it in the hole and use the wrench as a lever.
Old 06-20-2014, 11:53 PM   #4
Rewards Points: 59
Lefty loosey.
Replacement handle is no problem, but replacing the brass hinges is going to be a different story. They appear to be less common than others out there...
Old 06-21-2014, 06:41 AM   #5
DIY staff
Have you considered having them replated?
Old 06-21-2014, 08:50 PM   #6
Rewards Points: 59
Ah, that's a great idea! Will wait until I do the whole renovation...
The Following User Says Thank You to gnikyerffej1 For This Useful Post:
oh'mike (06-22-2014)
Old 06-22-2014, 08:50 AM   #7
DIY staff
If you are having trouble locating a plating service ---call or stop into a motorcycle shop---ask who they use----
gnikyerffej1 (06-22-2014)
Old 06-22-2014, 10:11 AM   #8
JOATMON
ddawg16's Avatar
Rewards Points: 820
One very important point....
Your glass is tempered.....if you nick it bad enough.....you will end up with a nice pile of small glass pieces....those doors have the holes pre-drilled before it's tempered. Once it's tempered....no holes.
The Following User Says Thank You to ddawg16 For This Useful Post:
Can you recommend a whole house fan? liquidvw General DIY Discussions 30 07-11-2011 11:48 AM
