#1 |
house with no foundation
The bathroom on the old 1905 placed on dirt instead of a foundation house, has the floor sills rotted. You can't jack anything up because there is no support to jack. Is there anything that can be done ? Build a second wall fastened to the first ?!?! It is not worth putting a lot of money into because of the overall condition. Especially after a water pipe under the house rusted through and caused the entire house to shift in opposite directions. As this is an old mining town, a lot of houses were just built on dirt.
#2 |
the Musigician
"Things" can certainly be done. But we'd need photos and details. Can you use the rafters? You can lay boards down and jack to the roof rafters, add straps if needed so the wall lifts too... Then put down PT sill and attach to (repaired) wall studs.
DM
[SIGPIC][/SIGPIC]Click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. to see some of my original magic tricks and trick boxes! |
| Display Modes | |
| pool house foundation | stemit1 | Building & Construction | 3 | 03-04-2010 12:19 PM |
| Should I bolt my tri-level house to the foundation? | SeattleDuck | Building & Construction | 2 | 10-16-2009 05:50 PM |
| Foundation Repair Help | rasilun | Remodeling | 1 | 10-15-2009 11:26 PM |
| House Foundation Painting | jwags | Painting | 3 | 09-26-2009 01:48 PM |
| I bought some land with old house on it, is it worth fixing? | jayinwww | Building & Construction | 2 | 04-17-2009 11:55 AM |
