High Bar Support - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 01-04-2013, 11:21 AM   #1
Rewards Points: 578
High Bar support
We are to the point in the kitchen redo where cabinets are about to go in. We finished rewiring with GFCI outlets, ran dedicated lines for all required appliances and covered the walls in beadboard paneling. Floors are going in soon, they are Ellerton laminate. I know, not the best, but doable until we have kids. We found some plans to make our own base cabinets out of plywood and 2x4's, and we plan to make them all over the next week or two.
On the back side of the kitchen, there is going to be a 30" stove, 8' of cabinets including the sink, then a corner cabinet with 5' of cabinets jutting out into the room to divide the living room from the kitchen. On the living room side of the peninsula, i want to put in a high breakfast bar. It will have the same laminate countertop that the rest of the kitchen will. The base of the high bar will be covered in beadboard, as well as the end of the bar and peninsula that will be visible from the living room.
Sorry about the novel. My question is, what kind of support do i need to put on the back of the peninsula cabinets to hold up the bartop? Can i just make a row of vertical 2x4's, like a half-wall, then use cornices to support the bartop? There will be no drywall on it.
There are no pictures because i have not actually built these cabinets yet.
TrailerParadise is offline   Reply With Quote
Old 01-04-2013, 11:28 AM   #2
Rewards Points: 578
The way im planning, it would have the cabinets, with 3/4" backs, then a row of vertical studs screwed to the floor and to the cabinets, cover the studs with beadboard nailed directly to the studs, then have the laminate bar top screwed to the top stud, with three small cornices screwed to the studs and bar top. Would it work?
Old 01-04-2013, 12:06 PM   #3
Ole Wood Worker
BigJim's Avatar
Rewards Points: 536
Sounds like a plan to me, I don't think you will have problems with it built like that.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 01-04-2013, 12:25 PM   #4
Rewards Points: 120
I agree; it sounds like a reasonable approach. Obviously start with some manner of plan, then build and tweak as you go.
It sounds like you have a lot going on there, so, if there are any in your area, you might want to consider dropping by a Habitat Restore, and see what they have in the way of cabinets. Building your own can be fun, but it does require a fair amount of time and money, and I know that our local Restore anyway has had some very nice cabinets at various times, some even brand new, which could be reworked a bit for a lot less money than starting from scratch.
The Following User Says Thank You to DexterII For This Useful Post:
BigJim (01-04-2013)
Old 01-04-2013, 12:29 PM   #5
Rewards Points: 13,994
Also check on Craigs List.
Old 01-04-2013, 01:43 PM   #6
Rewards Points: 578
ive been checking Craigslist but every time someone posts cabinets, theyre gone within two hours and they always post during the day while im at work.
There are two Restores in my area, one is close by and kinda small so they dont really have anything except appliances and normal furniture, and the other is kinda far away and i can only go on Saturdays. Its difficult to manage that type of schedule with work and a remodel so thats why i decided it would be easier to DIY the job. We are attempting the first cabinet tomorrow, so we will see how it goes. Ive also looked at the stock cabinets at Lowes, Home Depot and Surplus Warehouse, and they are all weak, pathetic looking particleboard. Surplus had some made of plywood, but they were so plain that i didnt feel that it justified paying the price for them, when i can get $50 in plywood from Home Depot and build it myself with a bit of glue and a Kreg jig
Thanks for the reassurance, guys. I appreciate your help!
Old Weather Head support connection problem RMCNABB Electrical 2 06-17-2011 04:27 AM
Sunroom extension support footings repair + cost gentlemansbeard Building & Construction 11 03-25-2011 02:40 PM
Rheem Criterion 2: high fan heat only dyincolor HVAC 2 03-27-2010 09:17 PM
How to add another support beam under floor joists LOStouten Carpentry 3 11-13-2008 10:55 PM
Adding support to "springy" floors-this mom's got to do it herself! LOStouten Building & Construction 10 11-12-2008 08:38 PM
