Hiding Pipes Inside A Wall? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 04-16-2005, 01:53 PM   #1
Hiding pipes inside a wall?
Hi I am new to the forum, so I am sorry if this question has already been asked.
I am re-fitting my bathroom.
Before I start re-tiling the walls I want to hide the water supply to the shower.
This is a Std copper water pipe which comes out of the wall about 12" from the floor.
The pipe goes upwards about 5 feet and then into the shower.
I would like to hide this pipe by cutting a channel into the wall and then tiling over it.
The wall itself seems to be a cavity wall 1 brick thick on either side of the cavity which has been plastered.
My questions are as follows:
1/ Is it possible to cut a channel into the wall in which to hide the pipe.
2/ If the answer to 1 is yes, is there a specific tool I can use to achieve this?
3/ Are there any things I need to be careful of when carrying out the above operation.
4/ If it is not possible, are there any other options that are not going to be an eye sore.
Thanks in advance.
Marvlin
Marvlin is offline   Reply With Quote
Old 04-19-2005, 01:40 PM   #2
I cut two groves using a five-inch angle grinder (fitted with a diamond blade) about 30 mm deep and 50 mm apart, then chase out with a cold chisel. Pipe should fit in grove, use slip on hair-felt insulation to allow for thermal movement.
Beware of live electrical cables and water pipes
dirkgently is offline   Reply With Quote
Old 04-20-2005, 01:15 PM   #3
Nice one cheers
Old 04-29-2005, 03:28 PM   #4
to do this you can either use a electric wall chaser or a good old hammer and chisel,once the pipe is in place use a plastic trunking to cover the pipe first,then plaster and tile ver or paint...........................pls make sure there is no power cable near to where you are chasing the wall.
makaveli is offline   Reply With Quote
