Help Updating Kitchen Cabinets, Etc. - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 05-07-2010, 01:16 AM   #1
Help updating kitchen cabinets, etc.
Hi there,
We just closed on our first home last week. Our money is a bit tight right now, so we don't really have the resources for the type of remodel this kitchen deserves. However, I'm wondering if a couple buckets of paint and some cheap floor might be a good temporary fix?
So, I need some help visualizing the potential.. I'm open to putting down some laminate or manufactured wood floors.. the counter and appliances are staying the same for now. What color should I do the cupboards, etc.?
Thank You!!!!
crystalsophia is offline   Reply With Quote
Old 05-07-2010, 06:10 AM   #2
Laminate flooring is fairly easy for even the casual DIY, vinyl can be a bit more difficult, either dress up the room. Painint is an option, but clean everything with TSP first, and use an oil base paint for durability. Another option is to strip and refinish the cabinets, but very messy and takes a while. Or if they are not too bad, just clean, sand lightly, and add a coat of oil poly.
Old 05-07-2010, 04:34 PM   #3
Rewards Points: 152
Older cupboards are generally built better than all but the best available today. If yours are well-built, I'd consider replacing just the doors (if sanding etc. won't work). If they're not too beat up, sanding &/or stripping wouldn't be a huge problem (they're flat pieces of wood) - remove the doors, take to garage, & get busy (there are good, safer strippers out there). Are the two square corner areas (either side of the cupboards along the stove) available for storage or did they seal them off? If not available, I'd somehow modify to provide some storage for things you rarely use. It would require a saw & some creativity, but I've done it before!
lazzlazz is offline   Reply With Quote
Tags
kitchen cupboards painted
Kitchen cabinets - Are Ikea cabinets good? What other mfgs have you used? whataboutj Kitchen & Bath Remodeling 24 11-09-2012 06:14 PM
Painting Kitchen Cabinets, Back wall NewlywedKristin Interior Decorating 12 03-18-2010 10:23 AM
Installing kitchen wall cabinets higher than spec recommendation? alexz General DIY Discussions 14 07-20-2008 11:32 PM
My Kitchen Floor-Problems!!! Please Help!!! Fat b Flooring 3 01-25-2007 03:21 PM
Kitchen Cabinets and Walls ththomps Remodeling 4 09-18-2006 10:23 PM
