Help Please-Replacing Baseboards & Have Existing Tile Floor - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 07-28-2012, 12:16 PM   #1
Help Please-Replacing baseboards & have existing Tile Floor
I already have tile floors and i want to change my baseboards to something more elaborate. the tile was installed a few years ago while the baseboards were built with the house 15 years ago. so, the baseboards are actually lower than the tile...in other words the grout butts upto the baseboard. can the baseboards be removed without breaking the tiles?
precious mack is offline   Reply With Quote
Old 07-28-2012, 04:26 PM   #2
Rewards Points: 616
can be done but not very fun i would also try to use thicker trim
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is online now   Reply With Quote
Old 07-28-2012, 09:43 PM   #3
Rewards Points: 512
ya that is not cool! what a lazy flooring guy. its going to take some time and patience to take out that baseboard without messing up the tile and then you'll have to go with a larger base or a base then quarter round.
princelake is offline   Reply With Quote
Old 07-28-2012, 11:03 PM   #4
Rewards Points: 12,822
I'd use my ossilating tool with a diamond blade to remove the grout before removing the base.
mae-ling (07-28-2012)
Old 07-28-2012, 11:10 PM   #5
Rewards Points: 2,202
Joer got it.
Remove grout, carefully, carefully remove base.
Then maybe a baseboard and shoe moulding.
Like 1/4 round but 1/2" by 3/4"
mae-ling is offline   Reply With Quote
Old 07-29-2012, 12:13 AM   #6
In a little over my head
Rewards Points: 706
Or, how about using the osc tool to cut the base flush with the floor, then install new thicker base and shoe?
ratherbefishing is offline   Reply With Quote
The Following User Says Thank You to ratherbefishing For This Useful Post:
hand drive (07-29-2012)
Old 07-29-2012, 08:55 AM   #7
AHH, SPANS!!!
Rewards Points: 1,166
Exactly. Cut old base flush with top of tile with sawz all, multi tasker, etc. Yank out old base and place new base down to top of tile level and then quarter round to cover any grout that may have cracked along the base.
hand drive is offline   Reply With Quote
Old 07-29-2012, 09:47 AM   #8
DIY staff
Rewards Points: 7,174
Use a large painters tool to pry the molding out a bit---place the tool on top of a nail--strike with a hammer--and the nail will be removed--
Do this to every nail and the base mold will lift straight up and out of the hole-----------
Old 07-29-2012, 09:52 AM   #9
AHH, SPANS!!!
This will work for larger base but a smaller base, say -3 1/4 base would not pivot easily without binding/crunching heavily against the grout.
Old 07-29-2012, 09:57 AM   #10
DIY staff
Some grout removal will be needed--however the drywall is usually missing behind the bottom of the trim--so I usually pop the trim loose first---then see if grout need to be removed--
Some times --using the painters tool like a chisel and cleaving the base mold at the floor will also free it up.
Old 07-29-2012, 10:06 AM   #11
Rewards Points: 512
just mike holmes it! just gut the place and redo it
Old 07-29-2012, 10:19 AM   #12
AHH, SPANS!!!
I have nightmares of three level deep flooring and having to remove the base board in old homes where 20 penny finish nails are the norm
Also, I'm a carpenter so not touching the grout and working around it is my first priority to get the job done without calling the tile guy
Old 07-29-2012, 10:43 AM   #13
DIY staff
I started life as a carpenter---then a tile guy---so I have the tools and experience to deal with both surfaces----
Splitting the base at the point its trapped works for me very often---
Tags
baseboard removal , tile floors
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 02:37 PM
Should I remove tile floor after minor flood? dan1980 Flooring 5 05-24-2012 04:48 PM
Steps for replacing tub, copper pipes, and tile floor??????? jsage5 Plumbing 5 09-05-2011 08:15 PM
Replacing tile in bathroom floor (2x2 tile) Paul8434 Remodeling 1 09-05-2011 07:06 PM
Tile over existing tile floor? dwalls32 Remodeling 3 07-03-2007 05:19 PM
