Help! Kerdi In Bathroom Not Sticking - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 12-11-2010, 06:19 PM   #1
Exclamation
help! kerdi in bathroom not sticking
Hi all i have a problem i am installing that orange kerdi membrane in my shower over cement board and i know it calls for unmodified morter thats what the schluter dealer sold me. its been 24hrs and it seems i can grab a corner of the membrane and pull it off the wall. it is supposed to become part of the wall rite.i went over it and got the air pockets out also i used there kerdi trowl witht the proper grooves any suggestions
lowgmc94 is offline   Reply With Quote
Old 12-16-2010, 08:34 PM   #2
Rewards Points: 292
I'm surprised nobody responeded to this. Did you mix your mortar correctly? It's the only potential problem that comes to my mind.
Jim F is offline   Reply With Quote
Old 12-22-2010, 09:43 PM   #3
Rewards Points: 5,336
As Jim said, the thinset needs to be on the thin side to adhere the kerdi.
Ron
Old 12-22-2010, 10:05 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Use "modified" thinset over cement board and once it dries don't be tugging on it.
Unmodified should still work but don't be trying to pull it apart. If you have air bubbles you haven't installed it properly. Your best bet may be to pull it all down and start over.
XXX
Can I install Kerdi over primed drywall in a basement bathroom? Mechelle Tiling, ceramics, marble 13 04-22-2012 10:50 AM
Bathroom DWV Layout Problems grymes56 Plumbing 8 05-15-2011 09:00 AM
Bathroom floor - Kerdi Band for Ditra / drywall joint? Airgibson Flooring 12 08-04-2010 09:33 PM
Basement bathroom wiring mess. Little help. trailblazer1229 Electrical 15 02-16-2010 09:29 AM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 10:42 AM
