Help With Insulation Behind Densgard - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 07-19-2009, 12:52 AM   #1
help with insulation behind densgard
I am doing a shower teardown. The insulation behind the existing floated morterbed (chickenwire) and greenboard has a shiny surface and states it is a vapor guard. I was going to put densguard over this existing insulation . Is this ok to do or does this cause a "moisture sandwich"?
FYI, I have already removed the insulation on the bottom half and was just going to put it back before I put up the densguard. If it is not ok would poking holes in the shiny surface remedy this "moisture sandwich"?
Any help is much appreciated. Also, any comments regarding densguard versus the other alternatives.? Densguard seems easy to use.
never ending is offline   Reply With Quote
Old 07-23-2009, 01:25 PM   #2
mgray87's Avatar
Originally Posted by tylerd View Post
Put some black paper before tile board.
Straight from Georgia Pacific's PDF instructions on Densguard installation:
"Do not use vapor barrier behind DensGuard Tile Backer, DensGuard has a built-in moisture barrier on the face."
mgray87 is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
2x4 Exterior Wall Insulation stubits Building & Construction 4 03-19-2009 08:03 AM
attic insulation question dderolph Building & Construction 10 11-03-2007 06:21 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 09:33 PM
