Hello: Need Bathroom Remodeling Help - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 02-04-2010, 10:08 PM   #1
Joined because I am in the middle of a bathroom remodel and I'm having trouble getting some clear answers. I've already completed tiling the floor, new vanities and toilet. I am now onto the tub area. The tiles and walls are removed and down to the studs. I'm at a stand still now because I'm so confused as what to do. Some say use a moisture barrier, some say don't. I live in Fl and one wall is an exterior with concrete block with 1x2 furring strips. Can anyone advise as to what I should do? Should I use some type of thin foil insulation on that wall like Reflectix. If so, would would I still use roofing felt or plastic in addition. I've heard it's not advisable to use 2 barriers..... any help would be appreciated. Thanks
jevs is offline   Reply With Quote
Old 02-05-2010, 11:07 AM   #2
Wink
Bathroom Reno
If you wanted to keep the bathroom temp more stable and keep the shower walls from feeling cold from the concrete wall, I would suggest some light insulation between the strips. Always use moisture barrier on exterior walls.
ryecandy is offline   Reply With Quote
Need help - bathroom remodeling manhattan Building & Construction 4 09-15-2009 07:31 AM
Remodeling a small bathroom tater1104 Building & Construction 1 09-14-2009 12:51 PM
We just bought a house and are thinking about remodeling the Bathroom Kellir Remodeling 10 07-16-2009 08:01 AM
Remodeling a small bathroom debd Remodeling 4 06-05-2009 03:24 PM
Basement bathroom remodeling amakarevic Building & Construction 2 04-12-2007 07:59 PM
