Hardwood Flooring Install - Kitchen & Bath Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-20-2017, 04:33 PM   #16
Rewards Points: 50
Re: hardwood flooring install
Originally Posted by JIMMIEM View Post
Is there a raised threshold under the door? Expansion gaps are a good idea. Consider using shoe molding against the tub to hide an expansion gap and seal the top of the shoe molding to the tub to keep water from running down and getting under the floor. l
I'm guessing i could just put in a brown colored caulk between the tub and last board? what kind of gap is recommend with hardwood 1/4"? thanks for your response.
owenpga is offline   Reply With Quote
Old 03-20-2017, 06:00 PM   #17
Rewards Points: 228
Manufacturer's installation instructions should provide a recommendation for expansion gap size. Good idea to heed it.....especially in a bathroom where there could be a water accident from the tub or toilet.
JIMMIEM is offline   Reply With Quote
Old 03-22-2017, 03:47 PM   #18
Rewards Points: 50
going the tiling route if i can. in the attached photo the two lines represent the joist. when i step behind the flange there is a bit of give under foot. the next joist is about 5" under the drywall which i'm thinking i could get to if i cut out along the green lines and maybe 6" out from tub. if i can put 1 or two supports in and patch the hole, then i should be good to put additional ply on top.
i'm not sure if just putting additional ply on top will take out enough deflection. the subfloor is 1/2"
Old 03-22-2017, 04:49 PM   #19
Rewards Points: 50
considering going the tiling route if i can....
in the attached photo the two lines represent the joist. when i step behind the flange there is a bit of give under foot. the next joist is about 5" under and behind the drywall. if i cut out along the green lines and maybe 6" out from tub and take out that section, i could possibly put a support in and patch the hole, then i should be good to put additional ply on top.
Attachment 78670
Old 03-23-2017, 12:44 PM   #20
Registered User
Rewards Points: 5,498
You had the correct idea to stop moisture from a crawl space into the bathroom, as you said "sealer" against wood floors. Better yet is to use a low perm rated sheet goods- not tar paper (5-30 perms)- but eg.- less than 1 perm; https://www.fortifiber.com/wp-conten..._aquabar_b.pdf
Are you sure there is not another joist- 4" out from the wall (w, toilet supply valve), that is 16" from the plywood joint towards said wall? Notice the rusty nails there...
Why are you replacing the existing ply rather than add some more to stiffen it?
How high do you need to add once you decide on which product to use?
Gary
Hardwood Flooring Pricing and Install 7 VII 7 Flooring 22 03-18-2013 10:39 AM
Should I install the doors first or the hardwood floors? DrTude15 Flooring 2 11-22-2012 11:16 AM
3/4 Hardwood Flooring over sufficient subfloor? bout time Flooring 3 06-20-2011 05:15 AM
What type of Hardwood Flooring for Concrete Slab? talk show host Flooring 5 01-22-2010 08:37 AM
A couple of Hardwood flooring questions drtbk4ever Flooring 12 01-24-2009 09:51 AM
