Hardibacker Overlapping Or Sitting On Top Of Tub Tile Flange?? (Pics) - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 08-10-2011, 09:02 PM   #1
Rewards Points: 35
Hardibacker overlapping or sitting on top of tub tile flange?? (Pics)
Hey Guys and gals,
I'm installing hardibacker CBU around my tub so I can tile the walls and I am a bit confused on what to do with the tub tiling flange. I have read to overlap the tile flange, or to rest the CBU on top of it and fill the void with anything from caulking to thinset. I've attached a picture for reference. Overlapping the tile flange would work except that the tub clips are very thick and would cause distortion in the CBU. But resting the CBU on top of tile flange seems impossible either with these clips? Even if I did "grind" the CBU where it overlaps the clips it would still leave a big void to be filled. What would the void be filled with, thinset?
What's the proper way to do this?
Hardibacker overlapping or sitting on top of tub tile flange?? (Pics)-pic-0347.jpg   Hardibacker overlapping or sitting on top of tub tile flange?? (Pics)-pic-0348.jpg
tunabreath is offline   Reply With Quote
Old 08-10-2011, 09:45 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Throw the clips in the trash and bring the wall-board to the top of the tub lip. Gap it 1/8" then caulk that gap with a suitable caulk, not 100% silicone. Install the tile and allow it to come within 1/8" of the top of the tub rim. Caulk that gap also using a grout-matching caulk.
XXX
Old 08-10-2011, 10:44 PM   #3
Rewards Points: 35
Get rid of the clips? How will tub movement be controlled without anything securing the tub to the studs?
So this is what it should look like from top to bottom:
Hardibacker
1/8" gap
top of tiling flange
My concern is the height of the tiling flange of this tub. If I do as you say, it would leave a half inch or more (at least) where the tile will have nothing behind it to support it?
Also, the distance from the top of the tiling flange to my ceiling is around 6' 6". I hung hardibacker starting from the ceiling down and my final piece of CBU left to be hung is a 6" strip. Will that be an issue since it will be near the tub or should I place the 6" strip on the top and have a full sheet complete the transition to tiling flange? I'd hate to have to take it all back down.
Old 08-10-2011, 11:39 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Your question was....
Asked and answered.
Fill it with thinset.
I would have done it the other way but if you have already installed the board why ask now?
That's why you caulk it on three sides.
The clips are a stupid idea but you do whatever you want.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
gregzoll (08-15-2011)
Tile over Tile ?? Piney Flooring 17 02-06-2012 09:59 PM
Bathroom tile installation demolition Kitchen & Bath Remodeling 4 04-10-2011 07:48 PM
Best Way To Do tile With Toilet Flange In Place JoeLena Plumbing 2 02-27-2011 01:55 PM
best way to cut tile in place diy888 Tiling, ceramics, marble 15 02-11-2011 12:48 PM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 02:14 PM
