Hardibacker Board Vs Cement Durock Board - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 02-17-2011, 12:38 PM   #1
Rewards Points: 103
Hardibacker board vs Cement Durock board
Hello,
Last year I remodeled my son's bathroom and used cement durock boards for walls and floors for tiling. This year I am planning to remodel my bathroom. I am going to put new walls with tiles around tub and shower and new tiled floor. I went to HomeDepot and salesman recommended me to use hardibacker boards instead of durock cement boards because it is easy to cut them. However, I am not sure about Hardibacker boards reliability in wet areas.
Any opinion or suggestion please?
Thank you.
sukhenkoi is offline   Reply With Quote
Old 02-17-2011, 08:32 PM   #2
Rewards Points: 276
My opinion is to stick with what you know and be very wary of advice you get from HD employees. Durrock will be fine for what you are doing.
Jim F is offline   Reply With Quote
The Following User Says Thank You to Jim F For This Useful Post:
sukhenkoi (02-18-2011)
Old 02-17-2011, 08:50 PM   #3
Rewards Points: 558
Durock's been around for awhile now and it is cement, it is more substantial and very good in wet areas and if you use a carbide tipped circular saw blade you will get nice clean straight cuts. Itís also heavier than the hardibacker because itís made out of cement it takes screws very easily using the required screws. So my vote would be DurockÖ
epson is offline   Reply With Quote
The Following User Says Thank You to epson For This Useful Post:
Old 02-25-2011, 08:32 AM   #4
I am in the process of retiling my shower. I went with Hardibacker, I've heard the Durock can crumble/chip under it's own weight. However, "easy to cut" does not apply to HB. Scoring/snapping is a 8itch, I've heard Durock is much easier for this. I just liked the appearance of the HB more, seemed easier to work with, handle. But from what I understand, either will be fine.
Mr. Michael is offline   Reply With Quote
Old 02-25-2011, 09:28 AM   #5
Rewards Points: 558
Yes either will work. Just remember to keep the fasteners between 3/8" and 3/4" from sheet edges and 2" in from sheet corners and set fastener heads flush with the surface without overdriving.
Old 02-26-2011, 06:23 AM   #6
Both are excellent products. I have had a half sheet of hardibacker under my 57 Chevy for years(outside) to catch oil drips, just as strong as new. I have used both for years. I tend to lean to hardibacker, not as crumbly at the edges.
Hardibacker board vs Cement Durock board sukhenkoi Tiling, ceramics, marble 39 03-27-2016 09:35 AM
Cement Board to Green Board Question ryan5068 Tiling, ceramics, marble 10 05-12-2010 06:29 PM
Bathroom cement board dah General DIY Discussions 2 07-11-2006 06:25 PM
particle board / hardibacker fish3211 Flooring 4 08-10-2005 08:32 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
