Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling > Kitchen & Bath Remodeling
Old 02-01-2009, 07:50 AM   #1
Default Granite not installed correctly????
Hi,
I recently had granite installed in my brand new kitchen, the problem is I was looking under the cabinets yesterday and in the area closest to the long wall I have the granite is not sitting on the cabinets, but appears to be sitting on pieces of wood in some places. Further down the cabinet, the granite is sitting on the cabinets. I used a level to see if there was an issue with the cabinets not being level, and they are level, so I am not sure what is up. There also looks like there is no glue or caulk underneath the granite to glue it to the cabinets, is this normal? any ideas? Also, there are seams that are visible, are there any products that can color seams after the granite is installed. The place I bought my kitchen cabinets from recommended the granite guy, they have worked with him for 6 years and have had no customer issues with him, so I am not sure what is going on. I have pointed out several other granite issues to the granite guy, but now I am worried that there is some stuff I am missing, or the guy really messed up my installation. Should I hire a third party to look at the kitchen and tell me what the issues are? What type of expert granite person could I hire, is there some sort of assocation of granite fabricators? Any help would be appreciated.
debsc is offline   Reply With Quote
Old 02-01-2009, 08:23 AM   #2
011000100110111101101111
DangerMouse's Avatar
the 'pieces of wood' were likely to level it.
not sure why you cannot see how it's mounted, (glue, clips, etc.) without seeing it.
pictures may help
DM
Magical, Musical, Mysterious FUN!
http://www.youtube.com/user/MickeySoume
Now Featuring: Mickey's Multi-Talented Mutts!
Old 02-01-2009, 09:06 AM   #3
Thanks for replying, I looked again and I cannot see anything, glue, clips etc.. that is connecting the cabinets to the granite.... here is a pic of the wood underneather the granite. I think they are there to level it, but the question is, if the cabinets and the floor are level, why would the counter top not be level??
Old 02-01-2009, 09:29 AM   #4
they evidentally found it not level in some areas, therefore the shims, and i suppose they used gravity-glue since it's so heavy?
does it shift or move at all? if so, inject some 'PL' (construction adhesive) in the gaps here and there, and the next day, it will not move.
DM
Old 02-01-2009, 10:01 AM   #5
Michael Thomas's Avatar
From the Design Manual produced by Marble Institute of America:
Residential Stone Counter Top Installation:
- 2.17 Spans & Overhangs
- 2.18 Stone counter tops under 1-1/8" thick should not span more than 2'-0" between support centers. Spans should always be minimized. 3/4" counter tops should be installed on underlayment.
- 2.19 Unsupported overhangs shall not exceed 6" on 3/4" counter tops or 10" for 1-1/4" counter tops. In an overhang condition, the supported area must be firmly secured and properly anchored to insure the unsupported area, when loaded, will not cause failure of the setting material. Mechanical anchors and gluing are recommend for overhang supports. If overhang exceeds the maximum amounts, proper brackets, legs or other rigid support must be added by the cabinet maker of builder
Michael Thomas is offline   Reply With Quote
Old 02-01-2009, 10:15 AM   #6
K&B Remodeler/Tile Guy
angus242's Avatar
This doesn't sound like an abnormal installation (although maybe a bit sloppy). Shims are commonly used to keep the granite level. You cannot truly measure the cabinets after the granite is installed to see if they're level. Put your level on top of the granite. Is that level?
Also, believe it or not, just a few dollops of silicone are used to hold the granite to the cabinets. If you've ever had to remove something that was held in place with silicone, you'd know its adhering capabilities. That along with the overall weight of the granite, your counters aren't going anywhere.
Angus
My Albums
angus242 is offline   Reply With Quote
Old 02-01-2009, 10:54 AM   #7
Thank you for all your comments. Sent an e-mail to the fabricator for him to come by next week to go over some of the issues I have. I think you are right, just sloppy work nothing major wrong.
Old 02-01-2009, 10:58 AM   #8
Also, I did measure the cabinets to see if they were level before the granite was put on. I had major problems with the floor being uneven, I had to have the tile down up, floor leveled, and then put back down so I was very careful that floor and cabinets both were level. I will see if counter is level.
More On This Topic
Hi this is Jon on behalf of Expert Village in this video clip we will be installing the top. After installing the bottom piece I went ahead and flip up my chest of drawers up onto the work bench, this will really help when installing the top. The first... Read More »
Now, a lot of people don't have a lot of room to store things, and they forget about little sneaky places in their kitchen. For example, the back of their cupboard. Now, what can we put there? If you want, you can take little bottles, maybe the little... Read More »
Now let's come to "cupboard" - "chu gui". "Chu gui" we called another type of cabinet, because we this character, "gui". And "chu" here is something like "kitchen". So the kitchen cabinet, cupboard. Well the character "chu" it contains this wood radical... Read More »
Remember to center the medicine cabinet in your new bathroom. Learn how to add a new bathroom to a home, including tips on setting a medicine cabinet in this free home improvement video. Read More »
Small kitchen appliances can actually take up a lot of space. Blenders, mixers, toasters, can openers, food processors, slow cookers, pressure cookers and other appliances can't all go on the counter top or your kitchen will look messy. They will also... Read More »
[IMG] code is Off
Stonemark & Silestone Countertops......??? DepotDweller Remodeling 9 06-25-2009 01:44 PM
Granite Hearth/Saltillo tile transtion help SeminoleMike Flooring 2 02-08-2009 01:49 PM
Installed Granite w/ Top Mount Sink JackOfAllTrades Remodeling 5 02-02-2008 09:30 AM
Decorative Etched Granite Listello csteinke Remodeling 1 06-09-2007 01:54 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
