Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling > Kitchen & Bath Remodeling
Old 10-03-2011, 10:05 AM   #16
Glueing Countertop Laminate on Door
I have had the same problem with a couple different large dogs. Only thing that worked for me was the open diamond shaped metal mesh - not sure what it is called, but it is about 1/4" thick, not bendable like fencing. It stops them when screwed flush to a door. It is not a pretty looking fix but it worked. If it was not flush, they were able to get their nails behind it and pull it loose (screws gave way). Good luck.
Polly003 is offline   Reply With Quote
The Following User Says Thank You to Polly003 For This Useful Post:
Sonya_ (10-07-2011)
Old 10-03-2011, 12:55 PM   #17
STAFF
BigJim's Avatar
Cut their toe nails or have them taken out.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
BigJim is offline   Reply With Quote
Tags
door, laminate
Exterior Door Leak around Weatherstrip/Frame not Plumb woodardhsd Building & Construction 9 09-01-2011 06:17 PM
laminate flooring over basement door in floor... tonyg1 Flooring 0 08-18-2011 03:35 PM
laminate flooring contracting at sliding door ckgwalk Flooring 5 10-11-2010 12:05 PM
How do you install laminate flooring under door casings? Player Flooring 34 07-16-2010 05:55 PM
Possible foundation, door gap problems Jemo Building & Construction 1 02-11-2007 09:43 AM
