Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling > Kitchen & Bath Remodeling
Old 01-06-2011, 12:36 AM   #1
gap under bypass shower door track
I'm reinstalling metal-framed bypass shower doors in an acrylic or plastic tub.
The portion of the tub where the inside of the bottom track rests isn't flat (the outside edge of the track is on a flat part of the tub). There's a gap between the bottom of the track and the tub that is too big to fill with caulk. What type of material should I use under the track to fill the gap? If grout, is there a specific kind that works with plastic tubs?
thanks!
whydistartthis is offline   Reply With Quote
Old 01-12-2011, 08:43 AM   #2
Old School
cabinetman's Avatar
WELCOME TO THE FORUM
You could find a rubber weatherstrip that would look good. This may sound funny, but I've seen plumbers use screen door spline (round). There are various types of weatherstripping in various colors and shapes that may work. How large is the gap?
cabinetman is offline   Reply With Quote
Old 01-13-2011, 10:22 PM   #3
I ended up finding a clue somewhere...backer rod. I put that in and it filled the 5/8" gap, then put in caulk to waterproof it.
Thanks!
Tags
plumbing shower doors gap
Bypass Shower Doors mclail Kitchen & Bath Remodeling 1 12-05-2010 08:07 AM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 07:33 AM
Installing Bypass Shower Doors pianodude Building & Construction 2 09-08-2009 07:09 AM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 01:39 PM
Bypass Shower Doors Install Question houston Kitchen & Bath Remodeling 4 01-31-2009 08:55 PM
