Gap Between Prefab Showerpan And Bottom Row Of The Tiles - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 05-15-2013, 12:55 AM   #1
Gap between prefab showerpan and bottom row of the tiles
Do you need to seal the gap between shower pan and bottom row of the tiles on 3 side or leave it open? There seems to be two schools of thought - do not seal to allow water sipping thru tile/grout to escape; seal with caulk or silicon. I recently cleaned up the gap (which had few streches without any seal material) and filled it with caulking. After a few days, I am seeing a couple of areas where caulking is getting washed off likely from the water escaping. Any advice on what to do next?
Kamtek is offline   Reply With Quote
Old 05-15-2013, 09:05 AM   #2
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
There shoul be weep holes in the caulking so water that gets behind there can "escape" back into the pan / drain.
CoconutPete is offline   Reply With Quote
The Following User Says Thank You to CoconutPete For This Useful Post:
Kamtek (05-15-2013)
Old 05-15-2013, 02:14 PM   #3
Thanks for the tip. How many weeping holes do I need to make on each side?
river rock as the bottom for a shower pan.. good? vote4Pedro Flooring 11 12-26-2011 07:53 PM
