-   Kitchen & Bath Remodeling (http://www.diychatroom.com/f80/)
-   -   Gap between prefab showerpan and bottom row of the tiles (http://www.diychatroom.com/f80/gap-between-prefab-showerpan-bottom-row-tiles-179609/)
Kamtek 05-15-2013 12:55 AM
Do you need to seal the gap between shower pan and bottom row of the tiles on 3 side or leave it open? There seems to be two schools of thought - do not seal to allow water sipping thru tile/grout to escape; seal with caulk or silicon. I recently cleaned up the gap (which had few streches without any seal material) and filled it with caulking. After a few days, I am seeing a couple of areas where caulking is getting washed off likely from the water escaping. Any advice on what to do next?
CoconutPete 05-15-2013 09:05 AM
There shoul be weep holes in the caulking so water that gets behind there can "escape" back into the pan / drain.
Kamtek 05-15-2013 02:14 PM
Thanks for the tip. How many weeping holes do I need to make on each side?
