Gap - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 06-14-2011, 02:48 PM   #1
Gap
I have a 1/2" gap between my fiberglass shower stall and tub. This gap is located at the back corner and on the bottom where they meet. I tried caulking thats mold resistant but water still gets in. I need some info for the gaps and the larger corner gap. Could I use some type of fiberglass filler to start and then caulk?
Robert S is offline   Reply With Quote
Old 06-14-2011, 03:32 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Can you provide a photograph?
I can tell you that re-caulking something like that can be problematic. The joint must be totally dry. I mean TOTALLY dry. Even if you think it is dry it may still hold some moisture. Use a hair dryer and dry the joint, THEN caulk it.
If the gap is in fact as big as 1/2" then first stuff some foam backer rod in the joint and caulk over the backer rod.
I don't know of any type of Fiberglas filler that would be suitable for this application.
How about a picture? I may change my mind after seeing one.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
Robert S (06-15-2011)
Old 06-15-2011, 02:30 PM   #3
Gap
Thanks for the info,
I have heard so much about this backer rod,weather stripping. I pretty much will try anything.
