FRP For Use Over Tub/shower Unit - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 03-04-2011, 02:23 PM   #1
FRP for use over tub/shower unit
I'm thinking of using FRP(fiberglass reinforced panel) in my tub/shower area. The walls of the tub/shower are 72in. high which leaves approximately 16 inches of vertical wall and the ceiling which need to be covered with something water resistant. I don't want to tile and was wondering if anyone had utilized FRP in this manner, also how sucessful were they. I'm also open to other suggestions in order to cover these surfaces. I would be grateful for any help.
James1ret
James1ret is offline   Reply With Quote
Old 03-04-2011, 03:48 PM   #2
Rewards Points: 5,336
James1ret
Call the company and ask if the product is rated for use in a shower.
There are kits for shower walls sold in stores all over. do an internet search and you'll find plenty to choose from. Local big box stores sell them along with plumbing supply houses.
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
James1ret (03-04-2011)
Old 03-04-2011, 05:05 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Actually FRP will work. There is a hitch however. The panels require the use of plastic channel corners and unions and terminators. It is most important to be sure and fill the channel 100% with 100% silicone caulk during the assembly process. This makes a helluva mess and the silicone purges all over. Use a rag with denatured alchohol to keep cleaning up as you go. Don't wait to clean a purge, clean it immediately.
Install to the substrate with the proper construction adhesive.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
Glacier on my AC Unit? Where's Al Gore? livinginthepark HVAC 10 07-13-2010 03:59 PM
Replacing a condensing unit with a higher SEER rating unit tylanz HVAC 3 06-28-2010 04:44 PM
HEIL/ICP gas/electric self-contained unit -- blowing cold air, won't shut off AboveTheBULL HVAC 3 06-28-2010 06:23 AM
AC Window Unit Size, 10k or 12k? Tuksonrider HVAC 7 06-17-2010 11:35 PM
Central Air Outside Unit Cover czars HVAC 2 01-07-2009 10:23 PM
