Framing To Support Shower Seat? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 12-24-2011, 08:34 PM   #1
In a little over my head
Rewards Points: 706
framing to support shower seat?
I'll be installing a folding shower seat in my new tile shower.
It looks like this:
http://www.dreamlineshowers.com/Fold...ower-Seat.html
The walls are still open studs. I don't have the instuctions yet, but from the picture, I don't think the mounting flanges are 16" apart. How would you frame behind the wall? Additional studs? 2x12 between the studs? If the 2x12, how would you attach it to the studs? nails, screws, lags?
Thanks!
ratherbefishing is offline   Reply With Quote
Old 12-24-2011, 10:12 PM   #2
Rewards Points: 12,802
You should be able to down load an instrutions manual on that seat as to location and distace apart the flanges are.
Once you do just frame the wall and do a lay out on the studs. Mark it out and cut out an area on the studs and cut out the studs to 1-1/2" depth. Install 2, pieces of 2 X 6 not a 2 X 12. The reason it's really hard to find a 2 X 12 that's not split down the middle. Install it with 2-1/2 ceramic coated deck screws. Now it will be flush with the studs.
Old 12-26-2011, 01:08 PM   #3
Rewards Points: 706
Thanks, Joe. I like that idea. Since this is an addition, the wall we're talking about was an exterior wall, supporting some (hip) roof load. Are you still OK with cutting 1.5" out of 2 studs? I guess if the cross piece is a good fit, I haven't compromised the stud much. ???
Pivoting Shower door replacement questions inspectator Kitchen & Bath Remodeling 5 07-22-2011 10:00 PM
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 10:10 AM
Honey, I'm going to re-caulk the shower... homebound Remodeling 1 02-10-2009 10:11 AM
Shower Pan Liner Problem Hottrod33 Plumbing 9 02-02-2009 02:02 PM
Support Framing Around Ductwork mfleming Building & Construction 4 12-04-2008 02:45 PM
