Florestone Shower Pan And Tile - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 07-12-2013, 01:29 AM   #1
Florestone shower pan and tile
Florestone shower pan and tile-img_0173.jpgShould the first row of tiles rest on the pan? If not, how far above the pan should the tiles be set?
Also, for the most part, the Durock sticks out a tad, but there is one corner (about 2 inches in length) where the pan lip sticks out a little. Will this be a problem when tiling? Or will adding a little more thinset correct this issue?
Lastly, in the picture below, how will I tile near the corner of the front of the pan? It seems like a gap will be visible once I set that particular corner tile. The plan is to place a full size tile along the corner of the front pan, and then add a bull nose tile to finish it off.
Florestone shower pan and tile-img_0175.jpg   Florestone shower pan and tile-img_0174.jpg
Jay2013 is offline   Reply With Quote
Old 07-12-2013, 06:32 AM   #2
DIY staff
Rewards Points: 7,174
Fill the gap with thinset as you tile---or, prefill it if you are going to waterproof the board before tiling--which is a darn good idea.
As to the pan sticking out past the board----I usually skive off some of the back of the tile----if that will cure the issue---other wise you will have some ugly lippage----
