Floor Or Cabinets First? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 09-26-2010, 10:18 AM   #1
Floor or Cabinets First?
Getting ready for a total kitchen remodel. Just wondering if anyone has any preference or if there is a unwritten rule as to which comes first. Cabinets or floor? I have read that it may be personal preference or you can install your cabinets first then lay your flooring right up to them. I was thinking on flooring first. Thanks ...
FrankC is offline   Reply With Quote
Old 09-26-2010, 10:31 AM   #2
Enough is Enough
H. A. S.'s Avatar
I've done the floor first, when I was installing flooring; just butt it up against existing cabinets. All depends on your situation and personal preference. Allow for expansion...
H. A. S. is offline   Reply With Quote
Old 09-26-2010, 11:04 AM   #3
Chicago, IL
Michael Thomas's Avatar
Keep in mind that installing flooring inside a dishwasher opening my reduce vertical clearances far enough that some dishwashers may not fit under the counter top.
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 09-26-2010, 01:56 PM   #4
Thanks guys, good point Michael. I will make sure I can still accomodate the dishwasher
Old 09-26-2010, 08:13 PM   #5
DIY staff
Rewards Points: 7,174
Floors first---much faster,keeps the cabinets at the correct height -neater trim job, no shoe molding needed at the toe kicks---no messing up the cabinets with thinset ---the list goes on.
Old 09-26-2010, 08:19 PM   #6
Edited:
Floor first if you can but understand that the cabinets will still need to be shimmed and depending on the floor you may have to shim them quite a bit.
I just did a job yesterday where the floor was 1.25" out of lever over 10 feet.
wnabcptrNH is offline   Reply With Quote
