Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling > Kitchen & Bath Remodeling
Old 07-20-2012, 01:49 AM   #1
Floor in BATH
The home is on a slab and we want to knock down a nonload wall and make the bath bigger and add a shower and garden tub... which is easier to do... chip a 6-8" deep trough thru the cement slab to run the lines OR build a solid sub floor and run the lines under it.?
Also do I have to take it to the rafters and put up mold resistant dry wall or can I seal it with paint/coating?
THANKS
tp123 is offline   Reply With Quote
Old 07-20-2012, 06:48 AM   #2
Super Moderator
Floor in BATH
Open the floor to rearrange the plumbing---
Regular drywall is fine in a bathroom---except in wet areas--there you want a waterproofed tile backer.
Inline Bath Vent Switch Wiring Dano81 Electrical 3 05-09-2012 11:52 PM
Relacing a shower with a half bath seth Building & Construction 9 11-22-2011 11:58 AM
Adding Master Bath - layout ideas bainer1290 Building & Construction 0 01-26-2011 10:31 AM
Switching the Plugs in Bath Fan/Light MrBill_DIY Electrical 3 12-01-2008 07:45 PM
Complex challenge with bath exhaust fan - need help with solution! Honest Bill Electrical 6 11-02-2007 03:52 PM
