First Big DIY Project - Master Bath Remodel - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 01-31-2012, 06:06 PM   #1
First Big DIY Project - Master bath remodel
Hi all:
I promise not to be a flake and disappear. This is the one forum I've decided to post on and check faithfully.
Long story short, we have to update our house some to be able to sell it. We have to move because hubby works 60 miles away...and is getting weary of the commute.
Our house was built in the 70's, and it shows. We're updating our (small) master bathroom so it isn't a Hollywood Bath with the sink visible from the bedroom.
We've removed the mildew-y vanity and now are laying matching tile all the way to the wall in anticipation of a floating vanity or something that sits on top of the tile.
Next job. The shower walls are old tile...the grout is flaking off, there are cracks, and it is generally hideous. The general thought is that there is no way to *fix* the shower walls...we have to rip it out and start over.
We're fairly sure the tiles are not sitting on cement board...they're on plain drywall. EW. Is there a way to demo the wall by just cutting the walls into sections? Or should we chip off all the old tile, and then pull the wall out? We're also replacing the window in the shower because it's old and creepy.
Any advice is very appreciated.
Thanks guys.
Lynne
lynnethesunny is offline   Reply With Quote
Old 01-31-2012, 06:53 PM   #2
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,074
Yup. Our house was built in the 70's too, and I found soggy, moldy greenboard behind our shower tiles. I'm no expert, but I wouldn't attempt to save it.
When I did our shower I could peel the tiles off by hand. Or you could try punching a hole through the wall and yank. Whatever works for your situation. If there is a tub you are keeping remember to protect it.
Also keep an eye out for mold. I wore a mask and gloves, immediately bagged it, and took it outside.
A window in the shower is often bad news. They can allow water into the wall which can lead to water damage, rot, mold etc. I'll cross my fingers you'll get lucky, but keep in mind you may be opening a can of worms.
The Following User Says Thank You to Blondesense For This Useful Post:
lynnethesunny (01-31-2012)
Old 01-31-2012, 08:26 PM   #3
DIY staff
Rewards Points: 7,174
You have gotten good advice---take out the tile with the board if it doesn't just fall off.
Hollywood bath? I've been calling those "Motel baths" --
Old 01-31-2012, 09:50 PM   #4
We've got a leaky roof elsewhere in the house, so we're not strangers to water damage. I'm really hoping the window isn't a big issue. *haha*
Thanks for the advice. It really helped to type it out and sort of get a sense of the plan.
Old 01-31-2012, 09:53 PM   #5
So much more accurate. I doubt anyone in Hollywood has a bathroom this tiny.
The Following User Says Thank You to lynnethesunny For This Useful Post:
oh'mike (02-01-2012)
Old 02-01-2012, 09:40 AM   #6
DIY staff
Depending on the layout---I frequently use double doors (French doors) when building the new partition wall----this eliminates the big door swing that so often blocks up the furniture layout --
Old 02-01-2012, 09:55 AM   #7
Excellent thought. I'll pitch it to my husband.
Old 02-01-2012, 10:00 AM   #8
DIY staff
That is a standard practice for those 'motel bath' conversions----do your wall layout on the floor using blue painters tape---makes visualizing the finished product easier for most people.
Sometimes shifting the doorway off center will give you room for a linen cupboard ---
Old 02-01-2012, 10:42 PM   #9
Rewards Points: 81
Lynnthesunny, What are you going to replace the shower tile with?
Total Tool is offline   Reply With Quote
Old 02-02-2012, 09:54 AM   #10
*sigh*
Isn't THAT the question of the day. Do y'all have any suggestions? We sort of assumed replacing the wall tile with more tile was the only thing that was affordable.
I'd love to hear other ideas.
Old 02-02-2012, 12:04 PM   #11
Stuck in the 70's
Is it a stand alone shower or a tub/shower combo?
Can you post a pic?
Old 02-02-2012, 05:16 PM   #12
Here are some pictures. Don't judge.
Old 02-02-2012, 06:27 PM   #13
Rewards Points: 81
They sell tub surrounds designed for windows. If it was me and I was planning on removing the drywall I would probably get a direct to stud style surround.
Old 02-02-2012, 06:32 PM   #14
Thanks Total Tool. I'm checking those out now.
Old 02-02-2012, 07:17 PM   #15
DIY staff
Lay that one out on paper---Is the room 5 feet wide? Might want to put the tub on the end wall instead of its present location.
Need Advice About Walling for Bath Remodel bremdogg55 Drywall & Plaster 7 12-05-2012 01:07 PM
Adding Master Bath - layout ideas bainer1290 Building & Construction 0 01-26-2011 10:31 AM
Master Bath Remodel - Need Advice meth Building & Construction 8 12-07-2010 06:31 PM
Tiny Master Bath Remodel??? Orchdirector1 Kitchen & Bath Remodeling 14 10-30-2010 08:24 PM
Master Bath Shower Remodel with images MattCoops Remodeling 4 01-10-2007 04:16 PM
