Fiberglass Shower Repair - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 03-10-2009, 01:54 PM   #1
Rewards Points: 26
Fiberglass shower repair
My moms bathroom has a 1 peice shower stall. She noticed a small crack on the base of the shower. I ran water for 20 minutes and put weight in the area of the crack and I couldn't see any leaks from below. Is there any way to patch this and have it hold up or is my only option to rip it out and redo everything? She is on a tight budget, lost her job recently so I am hoping that there is some kind of clear epoxy that can seal this hairline crack since it's not leaking but I also don't want to do a "hack" job and have it start leaking in a month. Thanks for any help with this.
ponch37300 is offline   Reply With Quote
Old 03-10-2009, 01:58 PM   #2
Remodeling Contractor
yes it can be fixed with resin and match the existing surface. Check out this site http://www.getagripinc.com/products/fiberglass.php
Old 03-10-2009, 03:07 PM   #3
Rewards Points: 26
Thanks Bob, have you used that stuff before? How hard is it to use? Thanks again
Old 03-10-2009, 03:23 PM   #4
similar to patching your car or boat. So if you have not experience with these you may find someone to help.
Old 03-10-2009, 03:39 PM   #5
Rewards Points: 26
I have done some custom fiberglass on some show car stereos a few years back. Do you have to sand this? From what I read it comes with the color in the resin? When I did fiberglass we laid mat and then mixed the resin and soaked the mat and then sanded when it dries and then used filler to smooth it and then painted it. How does this system work, from what I got you pretty much just mix the resin and spread it on? Thanks
Old 03-10-2009, 03:43 PM   #6
that is about it, but sanding smooth to match finish may be needed depending on your existing finish.
Backerboard under Fiberglass Shower Pan? BillyDIY Plumbing 2 12-17-2008 01:47 PM
Shower door install in unplumb fiberglass surround screenporch21 Building & Construction 1 11-24-2008 02:36 PM
Replacing a fiberglass shower Proulx06 Remodeling 11 06-20-2008 04:50 PM
