Fiberglass Shower Base With Tiled Walls - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 03-22-2013, 08:59 AM   #1
Fiberglass Shower Base with Tiled Walls
I'm sure this has been asked many times, however does anyone have a link to a diagram or sketch on the proper way to transition tiled shower walls to a fiberglass shower base?
David
h2ojetga is offline   Reply With Quote
Old 03-22-2013, 09:33 AM   #2
Rewards Points: 14,300
It's done exactly the same as a steel or cast tub is done.
It's best to shim out all the studs enough so the tile board will sit over the top lip and sit about 3/8 from the top edge of the pan, the tile sits about 1/4 from the top of the pan, silicone caulking fills the rest of the gap.
1/4" lattis works for the spacer.
Old 03-22-2013, 09:39 AM   #3
Thanks for the clarification. What type of vapor barrier would you recommend to place behind the backer board?
Old 03-22-2013, 10:01 AM   #4
No vaper barrier, the water proofing that needs to be done to the tile board acts as a vaper barrier.
http://www.homedepot.com/p/Custom-Bu...WAF1/100169081
Old 03-22-2013, 10:07 AM   #5
got it. thanks for the help. Have a good day.
DA
Large Porcelain Tiles for Shower Walls BigJim Flooring 138 02-27-2013 08:23 PM
Frameless Glass Shower Install lynxpilot Kitchen & Bath Remodeling 12 10-23-2012 11:14 PM
Shower Base with Concrete Walls Matt Staben Tiling, ceramics, marble 4 07-07-2011 11:18 PM
Pre-fab fiberglass shower possibilities... RealHouswifOfOK Kitchen & Bath Remodeling 6 04-13-2011 09:10 PM
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 09:10 AM
