Faux Counter Tops - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 07-06-2012, 11:12 AM   #1
Faux Counter Tops
Has any one tried to use the "Granite CounterTop" Paint kits? They look very easy and are supposed to make formica, corin or laminate look like Granite. It looks so easy, I am thinking of trying it, but I am afraid if I mess it up, I will be stuck with a big expence replacing my countertops.
Cindzen@yahoo is offline   Reply With Quote
Old 08-16-2012, 08:42 PM   #2
Rewards Points: 89
I have not, but I'm about to try my hand at it. I'm not even buying the kit. I'm following some videos and websites and priming and painting mine with the granite "stone" spray paint, followed with a billion coats of polyacryllic. But then, my counters are 1970's faux yellow granite. They can't actually be any uglier. You might want to try a bathroom first? If you hate it, you can not use it on the kitchen, although the price is a bit high for some of them if you just want to experiment.
Lilion is offline   Reply With Quote
Old 08-16-2012, 11:00 PM   #3
JBosarge's Avatar
I used the rustoleum stone spray and then put rustoleum premium clear coat epoxy garage coating and it worked great! A lot of people are negative on painting counters I am not because it came out good for me. After epoxy cures I put oil based polyurethane for floors as final coat. I learned a trick after the fact, spray the stone spray then sprinkle mica flakes the LIGHTLY spray little more of stone spray the mica adds little more sparkle and realistic granite look I am in process of redoing my top coat to incorporate mica chips. You can get them at Joann's crafts they are mica flakes by stampendous I have also seen them on eBay but only opalescent color Joann's had a variety pack of colors. This is pic before mica chips. I'll be glad to show you a pic with flakes when done. I live in Louisiana and you can not apply epoxy with high humidity. We've had rain and humidity quite a bit. Seems like on days it's perfect to apply epoxy I can't do it but plan on finishing next time weather cooperates. I don't think you can put enough poly to get a smooth enough finish for a counter that is workable. The bumpiness almost impossible to clean and the epoxy makes smooth as glass finish. Have found it to be no more delicate than Formica as far as scratches. Just plan on not touching counters for bout a week while epoxy cures completely I needed a second coat of epoxy because my counters were not level and few places needed more epoxy this is why I am incorporating mica flakes had I not had to do second coat I wouldn't have bothered but I do think mica flakes will make a difference.i have them down just waiting to do epoxy now. Good luck and have fun doing it. I enjoy these types of projects maybe just the artsy side of me but I enjoyed it. Ps I did sprinkle a fine copper glitter to create shimmer
Faux Counter Tops-image-3124441445.jpg   Faux Counter Tops-image-214671707.jpg
JBosarge is offline   Reply With Quote
The Following 2 Users Say Thank You to JBosarge For This Useful Post:
lborries (01-06-2013), mae-ling (08-16-2012)
Old 08-17-2012, 03:57 AM   #4
Too Short? Cut it Again!
People seem to be having reasonably good luck with these products. My concern remains how such a thin film layer is going to hold up long term. They have not been around long enough to know yet. I should think you would have to be extra careful with these surfaces so as not to chip them off into your salad bowl, mashed potatoes or whatever. Bacteria getting in them when they crack or develop micro fissures you cannot see would concern me also.
That said, esthetically they do seem worth a try if you need to buy some time saving up for a kitchen renovation and new countertops and cabinets. I guess they could help if you are selling a property and need to spruce up the kitchen.
With any kitchen finishing projects be especially careful with the prep or you will have adhesion problems you cannot fix from the surface down.
And with any resins and epoxies always make sure the products are within their expiration dates or you could end up with a non-curing mess.
Old 09-19-2012, 10:07 AM   #5
it will hold up well if you take care of it. Dont cut anything directly on the countertop, and dont set hot bowls or pans directly on the counter and it will last. This should not be a big adjustment because even with real granite you arent supposed to do that stuff
firsttimeremode is offline   Reply With Quote
Old 09-19-2012, 10:16 AM   #6
Rewards Points: 89
Just wanted to reply again and say, I did decide to use the Giani paint kit and it looks really good. We finished it at the end of August and I'm very happy with it. It seemed much easier than the Rustoleum and got better reviews on Amazon.
You can see my before and after shots here: (Just take out the extra spaces. Most forums don't let you post direct links to other forums so I didn't want to get it removed altogether.)
www. doityourself . com / forum/ designing - kitchens - bathrooms / 477806-updating-40-year-old-cabinets . html
Old 09-19-2012, 10:25 AM   #7
looks great Lilion
The Following User Says Thank You to firsttimeremode For This Useful Post:
Lilion (09-19-2012)
What is the standard depth of kitchen counter tops RobertN Carpentry 3 10-29-2010 10:28 AM
Corian or Granite counter tops Jms92 General DIY Discussions 21 04-17-2010 06:18 PM
concrete counter tops rwongrey Remodeling 10 07-13-2009 01:25 PM
laminating counter tops ponch37300 Remodeling 3 05-13-2009 10:13 PM
attaching countertop analogmusicman General DIY Discussions 22 08-10-2008 11:53 AM
