Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling > Kitchen & Bath Remodeling
Old 06-26-2012, 10:42 PM   #1
hohadcr's Avatar
exterior caulking for bathroom?
I want my caulking in the bathroom really really solid. Should I use the exterior caulking in the bathroom? If that caulking stands out door severity, it should be a lot better than the bathroom caulking? Or no?
thx
hohadcr is offline   Reply With Quote
Old 06-26-2012, 11:26 PM   #2
Renovations contractor
Bonzai's Avatar
Caulking for what specifically ... Around tub, toilet base, glass shower door, vanity countertop sink, tiled shower corners?
As long as you use a quality product for its intended purpose and apply it correctly you will be fine.
Sent from my iPad using DIY Forum
Home Renovations & Repairs
Vancouver to Whistler & beyond
Bonzai is offline   Reply With Quote
Old 06-26-2012, 11:48 PM   #3
the best to use in bathroom is ge silicone II has fungicide in it to keep it from molding
be careful my advice only comes from general knowledge i know about the 4 rules it takes to plumb and they are
1 poop needs to flow down hill. 2 hot on left cold on right
3 i get a pay check on Mondays 4 do not chew finger nails at or after work.
jaydevries is offline   Reply With Quote
Old 06-28-2012, 09:43 AM   #4
hohadcr's Avatar
caulking for around the tub,high water moisture
Old 06-28-2012, 10:14 AM   #5
Super Moderator
Don't use exterior calk--Use silicone or one of the other caulks designed for bath and shower---
oh'mike is online now   Reply With Quote
Old 06-28-2012, 01:25 PM   #6
and get one that is mildew resistant
mae-ling is offline   Reply With Quote
