Epoxy Countertop - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 08-10-2012, 12:01 PM   #1
epoxy countertop
can i put an epoxy finish on top of a formica countertop to make it look like granite or concrete, etc.
southard is offline   Reply With Quote
Old 08-10-2012, 12:30 PM   #2
Civil Engineer
Rewards Points: 4,938
I have never heard of such a thing. Have you got a particular finish in mind? Epoxy is normally a clear finish, unless you add a colorant, which would look nothing like stone or finished concrete. Plus it would be difficult or impossible to get the epoxy to dry flat on formica, and it might not adhere very well.
Daniel Holzman is online now   Reply With Quote
Old 08-10-2012, 03:31 PM   #3
Rewards Points: 14,294
Go to Home Depot and look at the new counter tops there stocking. They have a roman ogee edge on the front and back.
They will hold up far better then any painted on coating, and look like real stone.
Old 08-16-2012, 08:36 PM   #4
Rewards Points: 89
I'm surprised no one on here seems to have any experience with this. I haven't actually done it, but I've been doing tons of on-line research and have found several different products and also some basic DIY videos. Rustoleum Countertop Transformations is an epoxy type product and has good reviews. There's also a product called Giani Granite countertop system, which is sponge paining with a epoxy-type overlay. I've seen several folks have painted, either with the granite faux finish spray paint or sponge paint, then cover that with either several layers of poly acrylic or with an epoxy resin called Envirotex Lite. The key seems to be to sand and prime very well. My countertops are hideous and I'm going to try the granite spray paint and poly, because the budget is tight and I can't really ruin them.
Lilion is offline   Reply With Quote
The Following User Says Thank You to Lilion For This Useful Post:
lborries (01-06-2013)
Old 08-16-2012, 10:33 PM   #5
Stop By Home Depot and look at the new type counter tops there carrying. There formica but have a Roman Ogee edge at the front and back and look just like stone.
I installed them in a rental I own and the tenet just loves them. Best part was they were cheap.
I would have spend more money and taken way more time to try and coat them with a coating that would not hold up as well.
Old 08-17-2012, 04:03 AM   #6
Too Short? Cut it Again!
See the concurrent post running and others. This comes up all the time and people seem to be having reasonable luck with countertop refinishing kits that are epoxy based.
Faux Counter Tops
Be mindful you are just putting a very thin layer of material on a laminate that by nature is going to try to resist adhesion. These products have not been out long enough to know how they will last. Bacteria growing in micro-fissures and cracks, and chips falling off into food would concern me.
Old 04-13-2014, 10:27 PM   #7
Granicrete / Aurastone Epoxy Countertops
I am curious, does anyone have experience with Granicrete products? I'm interested in hearing about whether the lighter colors yellow...I've heard about some UV protectant...does that work?
Thanks!!
cbarnz is offline   Reply With Quote
Old 04-25-2014, 02:44 PM   #8
Lazy Granite is a cheap way of getting the granite look
PropertyManager is offline   Reply With Quote
Old 11-01-2014, 11:36 AM   #9
Rewards Points: 6
sand them, acrylic paint however you want (see Youtube- how to paint granite / marble countertops), epoxy over the top. Looks *****in and super inexpensive.
ebshep is offline   Reply With Quote
Old 10-05-2016, 11:56 AM   #10
Rewards Points: 2
Re: epoxy countertop
Countertop Epoxy provides kits for this for DIYers
lizzysunshine72 is offline   Reply With Quote
epoxy countertop products. hit_em Remodeling 4 02-20-2012 12:53 AM
How to install countertop over washer and dryer R V Dunai Remodeling 13 08-21-2011 02:07 PM
Epoxy Questions bsmith95610 Flooring 11 04-02-2011 03:41 PM
receptable inside cabinet DIYGST Electrical 8 01-29-2010 07:05 PM
Countertop - Epoxy Granite over Laminate sdrachel Remodeling 1 09-19-2009 06:15 AM
