durock/wonderboard
If you will be adding tile without waterproofing the surface of the Durrock---simply press the mesh into the thinset as you tile---no need to tape and mesh before hand----there is a risk of creating high spots.
If you will be painting on a waterproof membrane --mesh and thinset before you waterproof--very thin so no hump---the waterproofing will fill small openings---
Where the drywall meets the rock should be a 'dry area'---if so the use of powdered drywall mud could be used---
