Durock To Tub Messed Up - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 09-03-2013, 02:04 AM   #1
Durock to tub messed up
I messed up...any suggestions on fixing? Problem: I installed the Durock board over the tub flange without furring out the studs. It didn't occur to me until I was installing the tub surround but went ahead and installed the styrene tub surround. All fit ok except at the base (flange) area as a space now exist and movement on the base area causes the caulking to open up. Would it be possible to draw a carefully measured line just above the tub flange and use a 1/16 or 1/32 mason cutter to cut and remove the portion of the Durock to just above the the flange and screw the Durock to the studs? Please advise!
brdiy207 is offline   Reply With Quote
Old 09-03-2013, 03:55 AM   #2
DIY staff
Rewards Points: 7,174
Have you removed the surround?
Sure the rock could be cut with an angle grinder--protect the tub from the grit and sand---
Without more info ,that's all I have for you------Mike----
Seal durock to cast iron shower receptor? rightit Tiling, ceramics, marble 2 12-08-2012 04:44 PM
Fixing my Durock Mistake ScubaGeekNC Flooring 12 05-24-2012 07:48 PM
Gap between tub and durock (not lip) megablok Flooring 19 04-05-2012 10:15 AM
Liner and Durock placement rightit Kitchen & Bath Remodeling 7 03-13-2012 06:35 AM
Durock Question md2lgyk Concrete, Stone & Masonry 7 02-18-2012 07:25 AM
