Durock / Insert Mudding Question - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 04-03-2013, 06:54 AM   #1
Trucon01's Avatar
Rewards Points: 510
Durock / insert mudding question
Hi All,
I will be taping and mudding my seams on the Durock later this evening and had a question. As seen in the picture, I have a Reditile niche installed. Do I fiber tape around the insert and then mud? Should I just mud?
I also plan on putting 2+ coats of Redgard on all walls. Should I not mud and only rely on the Redgard? Should I do all 3?
Thanks Everyone.
Jeff
Durock / insert mudding question-photo-2.jpg
Basement Demo started Jan 2012: View my basement progression!!!
Bathroom demo started Feb 2013: View my bathroom progression!!!
Trucon01 is offline   Reply With Quote
Old 04-03-2013, 09:40 PM   #2
Rewards Points: 960
I tape and mortar everything.
I'm not sure about that insert. You might want to check with the manufacturer about what to do with the edges, but I imagine you will tape and mortar them as well.
I prefer to use denshield, then you don't need to liquid waterproof everything.
cleveman is offline   Reply With Quote
Old 04-04-2013, 10:34 AM   #3
Trucon01's Avatar
Rewards Points: 510
After doing more research, looks like you use 100% silicone caulk around the perimeter, let cure, then RedGard it!.
Thanks.
OSB to durock install acfrqflyer Flooring 26 01-05-2014 04:32 PM
Mr - Firebox Insert Question vladimir General DIY Discussions 0 02-20-2012 11:20 AM
Durock Question md2lgyk Concrete, Stone & Masonry 7 02-18-2012 07:25 AM
1/2" or 1/4" Durock Cement Board? HanDIY Flooring 3 08-08-2009 01:03 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
