Door Swing And Clearance - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 10-20-2013, 10:11 AM   #1
Rewards Points: 236
door swing and clearance
i want to see what you guys would do.
the issue. the left bank of corner. i had to space the other over 1 7/8" in order for that door to not hit the corner cabinet = causing damage. i know i could put a spacer in there. but what if i flip the doors and move that one cabinet over to butt. then the doors would not hit, and they would mirror the doors on the right side, that i could butt with out a problem. also, mirroring the doors, would put the handles in a mirror layout = would look much more symmetrical.
door swing and clearance-img_2191.jpg   door swing and clearance-img_2189.jpg   door swing and clearance-img_2190.jpg
Fix'n it is offline   Reply With Quote
Old 10-25-2013, 02:26 PM   #2
K&B Designer
Live_Oak's Avatar
Late to answer, but shallower depth cabinets that open towards a deeper cabinet should always have a filler there, or should have a restrictor clip/cable limiter for the hinge to keep it from opening past 90. Or change the hinges out to the more restrictive opening ones.
In your pic above, both the cabinets to the right of the stove should have been planned to be right hinged though, IMHO. With the restrictor clip added to the shallower cabinet.
Do it right from the beginning if you only want to do the job once. It'll be cheaper in the long term.
Live_Oak is offline   Reply With Quote
The Following User Says Thank You to Live_Oak For This Useful Post:
wkearney99 (10-25-2013)
Old 10-26-2013, 08:53 AM   #3
Rewards Points: 236
yes, i know. and yes, a little poor planning. but, i am going to flip the right side cabs and adjust the doors. its not just about door swing. its also the "look" , as in, where the handles go.
Range hood clearance to top of gas range less than minimum joemc3 Appliances 9 02-28-2013 01:42 AM
Mini Can light Clearance BigJim Electrical 4 02-01-2013 10:57 AM
Above Roof Vertical Clearance - E3504.2.1 JeepNick Electrical 10 11-01-2011 09:58 PM
Sub panel clearance question Red Squirrel Electrical 2 05-09-2011 09:53 PM
Furnace Clearance avtck HVAC 0 01-02-2010 09:13 PM
