Do I Need Two Layers Of Grout Sealer? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 07-08-2011, 12:50 PM   #1
Rewards Points: 103
Do I need two layers of grout sealer?
Hello,
In my bathroom remodeling project I finished tiling and grouting and started sealing grout on walls.
I was planning to put two layers of grout sealer on tub and shower surrounding walls and only one layer of all other walls.
However, when I tried to put a second sealer layer, grout did not absorb sealer. It all went down on tiles and floor.
I am using the "Aqua Mix Sealer's Choice Gold" sealer, which is considered as one of the best.
Do I really need to put a second layer of sealer on grout on tub and shower surrounding walls? And what is the best technique to do that if I have to.?
Thanks a lot.
sukhenkoi is offline   Reply With Quote
Old 12-31-2011, 12:11 PM   #2
wraiththe's Avatar
Rewards Points: 97
I would really like to know: was the sealer so good, that it blocked the next application from absorbing. Since it is water based - that does make sense. What did you find out?
wraiththe is offline   Reply With Quote
Old 12-31-2011, 01:05 PM   #3
Rewards Points: 13,260
How long did you wait before coats?
Look on the can of sealer to see how long it should have been and if two coats are suggested.
Old 12-31-2011, 02:03 PM   #4
DIY staff
Rewards Points: 7,174
One heavy application is it--or wet on wet with no waiting--once it's dried the grout will no longer absorb any--it's doing it's job.
Old 01-14-2012, 07:43 AM   #5
Rewards Points: 103
I waited 24 hours before applying the second layer.
Old 01-14-2012, 07:53 AM   #6
DIY staff
If it soaked in then you did well--most times it won't.
No harm done---it's just there to make the grout easier to clean---
Grout sealer recommendations/tub shower stall with tile tzinho Flooring 3 04-11-2011 01:58 PM
Grout sealer recommendations? tzinho Tiling, ceramics, marble 0 04-07-2011 02:17 PM
Grout sealer advice turbomangt Remodeling 0 06-22-2010 09:38 AM
Grout sealer on porcelain tile. sukhenkoi Tiling, ceramics, marble 5 04-28-2010 04:51 PM
Grout sealer before or after silicone caulk ? SPS-1 General DIY Discussions 2 07-28-2009 10:30 AM
