Ditra Under Vanity Cabinets - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 07-01-2010, 11:03 AM   #1
Rewards Points: 150
ditra under vanity cabinets
I am doing a bathroom that has an 8 foot long vanity with two sinks. The owner wishes to keep the vanity if it is possible. In the past, for small vanities, I have always removed the cabinets.
I am doing a kerdi shower, with a ditra membrane on the floor. My gut tells me that I should remove the cabinets, and use the membrane up to the wall.
What I want to know, is
1. Is it possible to remove large cabinets without destroying them?
2. Is it ok to use Ditra right up to the cabinets (if I leave them in place) and stop there? There is a space under the cabinets where it appears that air can easily dissipate into the the room (there are holes inside the cabinets for the plumbing)
The floor is only 5/8" thick plywood. I was thinking about laying an extra 3/8" to 1/2" on top for strength. (If I got rid of the vanity, I would remove the 5/8" and replace it with new 3/4" ply.)
gramps416 is offline   Reply With Quote
Old 07-02-2010, 08:56 AM   #2
Rewards Points: 150
anyone?
Old 07-02-2010, 08:20 PM   #3
Rewards Points: 276
Are you talking about a granite counter top or some other breakable surface? They removed a large granite counter top on Holmes on Homes without breaking it but told the homeowner up front that it was risky and that it may break.
I'll let someone with tile experience weigh in on the other question.
Jim F is offline   Reply With Quote
Old 07-02-2010, 09:09 PM   #4
Rewards Points: 150
The counter top is the laminate type with the particle board core.
Old 07-03-2010, 11:12 AM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Seems a silly watse of time (and money) to remove the vanity when it isn't necessary.
Adding more plywood is almost always a good idea but had you researched DITRA you would know that it can be installed over a 5/8" subfloor. Why expose yourself to damaging the cabinet and vanity top if you don't have to and it isn't being replaced?
What the heck for???
XXX
Old 07-03-2010, 09:27 PM   #6
Rewards Points: 150
good points bud cline, I think I will not remove the counter tops
What I meant by the membrane going up the wall is, I always had the impression that ditra always had kerdi band at any termination point (a wall).
By installing Ditra over a floor that already has the cabinets installed, I cannot install kerdi band along the cabinets
-g
Old 07-05-2010, 12:24 PM   #7
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
First let me say I am not an expert by any means, but have been reading here for a long time researching my own project.
My understanding is Ditra an uncoupling membrane used under floor tile. Don't see a reason to put it under a cabinet.
Kerdi
and kerdi band are waterproofing products used in the shower. Someone correct me if I'm wrong, but I don't think you use kerdi band with ditra.
I'd suggest going back to their webpage and doing a bit more research.
Old 07-05-2010, 04:10 PM   #8
Newbie Bill
Rewards Points: 520
Blondesense is correct. Unless I am missing something, you don't need a kerdi band on the wall or cabinet unless it is in or immediately around the shower.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 07-05-2010, 09:40 PM   #9
You're both right,Kerdi band isn't used for Ditra,just for the seams in a shower with Kerdi.
tileman2000 is offline   Reply With Quote
Old 07-06-2010, 12:13 AM   #10
actually both gramps & blondesense are right.
it depends on the usage of the room. If the floor needs to be waterproof for whatever reason, schluter has specified u use kerdi band to go over the ditra seams, and also up a few inches of the wall.
otherwise u don't need kerdi with ditra.
acerunner is offline   Reply With Quote
Kitchen cabinets - Are Ikea cabinets good? What other mfgs have you used? whataboutj Kitchen & Bath Remodeling 24 11-09-2012 06:14 PM
bathroom remodel at a stand still becuase of floating vanity installation diy'er on LI Kitchen & Bath Remodeling 10 11-23-2009 01:12 PM
Installing kitchen wall cabinets higher than spec recommendation? alexz General DIY Discussions 14 07-20-2008 11:32 PM
How are the premade HD and Lowes Cabinets? twilightcall Carpentry 10 05-25-2008 10:23 AM
My Kitchen Floor-Problems!!! Please Help!!! Fat b Flooring 3 01-25-2007 03:21 PM
