Cutting Marble Back Splash - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 05-22-2011, 03:39 AM   #1
cutting marble back splash
installing a new microwave that wont fit because of a back splash is now to high. need to cut 1/2 to 1" off top of back splash . is it possible to cut marble/granet while on the wall?
trianglebluz is offline   Reply With Quote
Old 05-22-2011, 05:58 AM   #2
DIY staff
Rewards Points: 7,174
Yes,but it's messy.
A 4" angel grinder with a diamond bit is a start---then a milti tool with a modified diamond cutter.
Post a picture if it is possible.--It might be easier to build out the area above the tile and just mount the microwave out a bit farther than usual.---Mike---
Old 05-22-2011, 06:31 AM   #3
Rewards Points: 5,336
The issue with cutting material on the wall are the corners. Tools with circular blades can't get in the corners or too close to the cabinet sides. Even jigsaws will hit the sides before the blade gets to the corner.
Ron
Adhesive for Marble Threshold Twister Flooring 11 05-14-2011 01:20 PM
Cutting marble tile for fireplace - unsure of layout genEus Remodeling 11 04-16-2009 07:36 AM
Back Splash Tile Help TTran Building & Construction 15 01-12-2009 03:03 PM
Tile Back splash over stove - Waste of time? Mr Chips Flooring 5 07-06-2008 01:46 PM
Installing A Back Splash bobo Carpentry 3 09-09-2006 02:36 PM
